Possible to cURL for whether a recording has been "Verified" or not?
I'm working on adding an OliveTin Action that would use an EDL to add commercial chapter markers to Channels DVR recordings, but I'd like it to optionally trigger only when a recording's Comskip results have been looked at, and saved -- to generate a "Verified" tag. Is there an endpoint I could use to do that verification?
You can get this info in the Server API:
Thanks! Super easy -- should have looked there first. This is giving me the name, and verified=true:
curl -s http://media-server6:8089/api/v1/all | jq -c '.[] | select(.verified == true) | {title, verified}'
I'll just check for whether a matching EDL exists, and that should be most of what I need.
