Power mgmt Settings for MacBook Pro
Hi,
I have Channels DVR running on an old MacBook Pro sitting in a cabinet by the TV. The lid is closed and I have the power settings set so that the MacBook stays awake the whole time with the display off and runs Channels DVR. It's working, sort of and that's why I am here. Occasionally, the MacBook Pro really goes to sleep and when I fire up the Channels App on my AppleTV it can't find the DVR server.
Is there a guide to the correct power save settings for DVR Server running on my MacBook Pro?
I thought that Channels DVR includes an auto-wake helper app, but it sounds like that’s not working for you? Awhile back when I used an old MacBook Pro as a server for other purposes, I used this tool with good results:
Another newer option I have read good things about: ‎Amphetamine on the Mac App Store
I actually did not know of the auto-wake helper. I found the "Install auto-wake helper" link and clicked it. Let's see if that works better. Thanks for your help!
How did you know to install that? I thought I followed all the installation steps. Is there something I should have read?
I'm not sure, it's been a long time since I installed. I've just seen mention of the auto-wake helper here in this forum from time to time. My current CDVR server is an M1 Mac mini that's always on.
25 seconds in to the video guide on this page
https://getchannels.com/dvr-server/#macos
Oh man! :flushed: Thanks for this! I would have thought I did this already but...
Well, I tried the auto-wake-helper. It worked for a few days...until yesterday! So I will now try Caffeine or Amphetamine. Why is sleeping or waking so hard?
