Hi I haven't had this up and running to long but last night I had a power outage and the DVR service did not restart . Is there something I could do to fix this. Thanks
I'm not sure why a power outage would cause Channels to stop working on a Shield device, people do hard power resets by removing power all the time. Is it possible that you had a lightening strike and damage, or that the power outage somehow forced a Shield device reset and Channels DVR is no longer installed and/or running?
No I had to manually restart the DVR server. If I reboot the Nvidia Shield it does the same thing. I have to manually start the DVR server. Any help would be appreciated.
You need to make sure the DVR server software is installed on the internal storage. See Auto startup on Nvidia Shield
