I noticed that double-clicking play/pause on our remote to toggle between the previous channel only works on certain Apple TVs. Is it supposed to only be for select generations?
This one works:
While this one does not:
This one works:
It’s probably just not selected in the channels dvr app settings. It’s under settings, playback, jump to last channel.
No, I have 3 different generation AppleTV's and this shortcut works on all of them.
Just checked. I have it turned on as a global setting, so it can’t be that.
Update: Just went from a mid-January version to the latest pre-release and it looks to be fixed already
