Channels DVR setting only allows me to go one level deep and I can't get to my Movies folder
Did you install Channels DVR using the Synology Package?
If so, you need to give the Synology System internal user channels access permission to the import directories.
As mentioned here https://getchannels.com/dvr-server/#synology
