Problem recording local news
I have several passes created for local news programs throughout the day.
Most of them work fine, but one station has all of their programs listed as the same episode. So it records the first episode as expected and then never records another as it thinks it already recorded that episode.
Is there any way to solve or work around this issue? Any suggestions are welcome.
here's an advanced pass I set, might give you some ideas
I will give this a try. Thanks!
Channels DVR uses a unique ID (ProgramID) from the guide data to determine if the episodes are different.
What is your source for that channel (HDHR tuner, TVE, etc.)?
What does your pass look like (Advanced and Matches tabs)?
Here is a walkthrough to find the ProgramID for each airing of the show in your guide data Passes showing future airing of show as already recorded? - #9 by chDVRuser
And for each airing that displays in your pass Matches tab Re-record deleted episodes still ignoring some episodes - #7 by chDVRuser
