Problem with DirectTV Stream, then CDVR was not avail
Windows 11, USING onn 4k BOX.
I was watching the Science Channel using DirecTv Stream(DTVS) TVE and using a Channel Collection made up primarily of DTVS channels, and suddenly it paused with the spinning circle
and would not resume.
I kept trying, I tried FNC, still nothing, the logs below (highlighted in Bold) shows it tried to get FNC from Cox, not DTVS but failed
Then it would not start and play anything.
I tried going to Logs on my phone to see what was happening.... Nothing, CDVR was not running or responding,
only a black screen on the Phone.
Finally it became available again as I tried again, I reloaded the DTS Source, all valid CH authorized.
Then all was well again.
Any ideas, log below:
2025/03/26 18:33:22.788790 [ERR] ULK failure: Get "https://content-ause1-up-1.uplynk.com/session/ping/947fcebc7c0d4282b56815c4d0444789.json?v=3&pt=758": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
2025/03/26 18:34:14.867963 [SNR] Rewriter statistics for 192.168.0.242 (Den Onn) for ch6110 SCIENCE: discontinuity_detected=15 transport_errors=0 saw_pcr=false saw_pmt=true highest_pts=767.533133
2025/03/26 18:34:14.867963 [SNR] Buffer statistics for 192.168.0.242 (Den Onn) for ch6110 SCIENCE: buf=0% drop=0%
2025/03/26 18:34:14.867963 [SNR] Streaming statistics for 192.168.0.242 (Den Onn) for ch6110 SCIENCE: timeouts=2 segment_timeouts=0 playlist_timeouts=2
2025/03/26 18:34:18.136556 [TNR] Closed connection to TVE-ATTOTT for ch6110 SCIENCE
2025/03/26 18:34:32.602404 [ERR] Could not start stream for TVE-ATTOTT ch6110 SCIENCE: TVE: playback info: Post "https://us1-prod-direct.sciencechannel.com/playback/v3/channelPlaybackInfo": context deadline exceeded (Client.Timeout exceeded while awaiting headers)
2025/03/26 18:34:51.256671 [WRN] discovery auth failed, trying again with sci: discovery token: Get "https://us1-prod-direct.go.discovery.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.go.discovery.com: no such host
2025/03/26 18:34:51.260789 [ERR] Could not start stream for TVE-ATTOTT ch6110 SCIENCE: TVE: discovery token: Get "https://us1-prod-direct.sciencechannel.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.sciencechannel.com: no such host
2025/03/26 18:34:54.016322 [WRN] discovery auth failed, trying again with sci: discovery token: Get "https://us1-prod-direct.go.discovery.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.go.discovery.com: no such host
2025/03/26 18:34:54.043197 [ERR] Could not start stream for TVE-ATTOTT ch6110 SCIENCE: TVE: discovery token: Get "https://us1-prod-direct.sciencechannel.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.sciencechannel.com: no such host
2025/03/26 18:35:02.319250 [WRN] discovery auth failed, trying again with sci: discovery token: Get "https://us1-prod-direct.go.discovery.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.go.discovery.com: no such host
2025/03/26 18:35:02.334727 [ERR] Could not start stream for TVE-ATTOTT ch6110 SCIENCE: TVE: discovery token: Get "https://us1-prod-direct.sciencechannel.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.sciencechannel.com: no such host
2025/03/26 18:35:02.346555 action=requestor err=Get "https://sp.auth.adobe.com/adobe-services/config/fbc-fox?noflash=true": dial tcp: lookup sp.auth.adobe.com: no such host
**2025/03/26 18:35:02.348901 [ERR] Could not start stream for TVE-Cox ch6073 FNC: TVE: Post "https://sp.auth.adobe.com/adobe-services/shortAuthorize": dial tcp: lookup sp.auth.adobe.com: no such host**
2025/03/26 18:35:02.387036 action=requestor err=Get "https://sp.auth.adobe.com/adobe-services/config/fbc-fox?noflash=true": dial tcp: lookup sp.auth.adobe.com: no such host
2025/03/26 18:35:02.392771 [ERR] Could not start stream for TVE-ATTOTT ch6073 FNC: TVE: Post "https://sp.auth.adobe.com/adobe-services/authorize": dial tcp: lookup sp.auth.adobe.com: no such host
2025/03/26 18:35:02.443111 [WRN] discovery auth failed, trying again with sci: discovery token: Get "https://us1-prod-direct.go.discovery.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.go.discovery.com: no such host
2025/03/26 18:35:02.445964 [ERR] Could not start stream for TVE-ATTOTT ch6110 SCIENCE: TVE: discovery token: Get "https://us1-prod-direct.sciencechannel.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.sciencechannel.com: no such host
2025/03/26 18:35:06.568770 [WRN] discovery auth failed, trying again with sci: discovery token: Get "https://us1-prod-direct.go.discovery.com/token?deviceId=435A3917-CA0E-47C7-A5E1-B4049EB36F47&realm=go&shortlived=true": dial tcp: lookup us1-prod-direct.go.discovery.com: no such host
Looks like you had a brief Internet outage or DNS server outage.
Do you have a COX TVE source setup?
Are you running the latest pre-release server version?
Did you run the DVR Troubleshooting?
Yes Cox is my usual Source, but I don't have Science so I use the other Source.
Running latest STABLE Version 2025.02.19.1823
Did not run trouble shooting, CDVR was not available to try that,
But I just did, no problems.... all good now, so as expected.
You should update pre-release when you have TVE issues.
Latest is DVR Pre-Release Notes - #1714 by fancybot
I'd rather not use Pre release unless I'm desperate.
I don't usually have this kind of problem on reliable Sources.
This was very unusual, so I'll just keep watching and testing.
I sure hope this was a fluke.
