I have been using Channels DVR with a Synology 920+ that is ethernet wired directly to my Netgear Orbi RBK750 Router. ISP is Verizon Fios Gigabit which is an ethernet cable directly from the ONT to the Orbit router. I have been enjoying channels for about 4 months now. The clients are all firestick's. One of which is ethernet wired and the others are wifi connected. The issue I'm having is that for some reason in my Channels DVR settings it is showing 2 networks. Here are the relevant settings from the Channels DVR settings page...
Bonjour Settings: Advertising dvr-bqnas.local. via 2 networks: [192.168.1.2, 169.254.20.235]
Port Forwarding Listening on 100.14.68.164:8089
Support Tab: Remote Access Fail: b86a8deec3a9.u.channelsdvr.net is pointed at 71.246.29.74 but the current IP for this system is 100.14.83.36
When I setup Channels DVR initially I went into my router settings and created a static IP for the NAS of 192.168.1.2. Then followed the setup instructions for Channel DVR.
- How do I fix this multiple network issue?
- I have been noticing a lot of video and audio out of sync on many channels - not all, but many lately. How can I fix this issue? It doesn't seem to be an internet issue as all my clients have over 200mb/sec throughput.
Thanks for any help you can provide,
Ben
