I have a season pass set up for ‘Hey Duggee’. There are different lengths of episodes according to the guide (short and long).
In the guide, the short ones are 5mins, the long ones 10mins.
However, they are all actually 7 minutes long.
Sometimes there are two episodes in the guide (1 short and 1 long) aired together, so the 15mins is enough to cover both episodes, however I end up with one file that is truncated and the other has half of the other episode.
The result, as you can imagine, is essentially useless.
The only solution I can think of is to add a large amount of padding to each episode and then manually edit at a later date. Unless there is a better way?
Any help gratefully received.
