Problems watching iptv streams on Safari
The same stream (usually HEVC but also HD) that works using VLC not always working with Channels and xteve. I got bunch of "panic" errors and not sure should I panic or not ^^
2020/04/19 17:03:51 [Recovery] 2020/04/19 - 17:03:51 panic recovered:
runtime error: invalid memory address or nil pointer dereference
runtime/panic.go:212 (0x404c9e9)
runtime/signal_unix.go:695 (0x404c838)
github.com/grafov/[email protected]/writer.go:727 (0x4c8a303)
github.com/fancybits/channels-server/streaming/abr_live_stream.go:474 (0x4c8a349)
github.com/fancybits/channels-server/streaming/abr_live_stream.go:386 (0x4c89490)
github.com/fancybits/channels-server/http_device.go:516 (0x4da6a50)
github.com/gin-gonic/[email protected]/context.go:147 (0x45d41da)
github.com/fancybits/channels-server/http_device.go:35 (0x4d868d1)
github.com/fancybits/channels-server/http.go:231 (0x4d8393e)
github.com/fancybits/channels-server/http.go:211 (0x4d83522)
github.com/fancybits/channels-server/http.go:203 (0x4d825de)
github.com/gin-gonic/[email protected]/recovery.go:83 (0x45e730f)
github.com/fancybits/channels-server/http.go:286 (0x4d9c72b)
github.com/gin-contrib/[email protected]/sessions.go:65 (0x4cb4d92)
github.com/gin-contrib/[email protected]/gzip.go:47 (0x4cae0d0)
github.com/fancybits/channels-server/http.go:266 (0x4d9c501)
github.com/gin-gonic/[email protected]/gin.go:403 (0x45ddb22)
github.com/gin-gonic/[email protected]/gin.go:364 (0x45dd22c)
net/http/server.go:2807 (0x431f222)
net/http/server.go:1895 (0x431ab9b)
runtime/asm_amd64.s:1373 (0x40687e0)
2020/04/19 17:03:54.811505 [HLS] Probe failed for live stream after 3.161381161s and 0 bytes
2020/04/19 17:03:54.811554 [TNR] Closed connection to 2020-04-A40O-VI1HWB:2 for ch1027 |PL| KINO TV HEVC
2020/04/19 17:03:56.944807 [HLS] Stopping transcoder session ch1027-dANY-ip127.0.0.1
2020/04/19 17:04:02.112760 [TNR] Opened connection to 2020-04-A40O-VI1HWB:2 for ch1023 |PL| BOOMERANG HEVC
2020/04/19 17:04:02.119538 [HLS] Starting transcoder for channel 1023 from 127.0.0.1 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2020/04/19 17:04:02.148896 [HLS] ffmpeg: ch1023-dANY-ip127.0.0.1-remux: pipe:: could not find codec parameters
2020/04/19 17:04:02 [Recovery] 2020/04/19 - 17:04:02 panic recovered:
2020/04/19 17:04:05.393670 [HLS] Probe failed for live stream after 3.274022527s and 0 bytes
2020/04/19 17:04:05.393717 [TNR] Closed connection to 2020-04-A40O-VI1HWB:2 for ch1023 |PL| BOOMERANG HEVC
2020/04/19 17:04:14.789814 [HLS] Stopping transcoder session ch1023-dANY-ip127.0.0.1
2020/04/19 17:04:19.391472 [TNR] Opened connection to 2020-04-A40O-VI1HWB:2 for ch1022 |PL| TVN TURBO
2020/04/19 17:04:19.397062 [HLS] Starting transcoder for channel 1022 from 127.0.0.1 (encoder=remux, resolution=, deinterlacer=, bitrate=0)
2020/04/19 17:04:19.429605 [HLS] ffmpeg: ch1022-dANY-ip127.0.0.1-remux: pipe:: could not find codec parameters
2020/04/19 17:04:19 [Recovery] 2020/04/19 - 17:04:19 panic recovered:
