Problems with Fire TV app, but not MacOS app
Hi,
I am regularly running into something I find odd. I have Channels Fire TV app version 4.9.4, and MacOS app 7.0.2 on my laptop. Both are going over my LAN to my Windows 11 box running the Channels DVR server. I have a recording - again - that will not start playing with the Fire TV app. When I start it, the app exits or restarts, but the MacOS app Just Works. Sometimes the problem is a ways into the program - playback on the Fire TV app freezes, but I can restart from the saved position without issue on the MacOS app. The Fire TV app seems to trip over glitches, while the MacOS app seems resilient.
I can provide the recording in question if it's helpful. Obviously, getting the Fire TV app to act more like the MacOS app would be great.
Rob T
Are you saying that when you back out of the Fire TV app back out and go back in, it's a black screen?
If so, I experienced this on the NVIDIA Shield and they fixed it in the most recent beta.
Change to software decoding
I don't take action to exit the app - it dies on its own after spinning for awhile, and I am back at the Fire TV screen.
As in Settings -> Advanced -> Transcoder? I can try that next time.
I restarted the Fire TV stick and it's better for the moment, playing everything.
Rob T
