I love the Channels DVR, but I am having a few issues with TVE integration.
I added Sling to my Channels DVR, and my only issue there is Slings limited channels within TVE. But that is Sling's issue.
My other issue is with Locast integration.
I have 34 Locast channels showing in the guide, but it looks like only the major networks are actually being integrated into the Guide.
I am in the Atlanta area, and there is a channel called Peachtree Network that is listed as one of the available Locast channels, but I can not get it to actually integrate into the guide. I am using the edit function to try to get it to show, but still a no-go.
Are any of you guys having similar issues with Locast?
UPDATE:
If I check the server web page on my browser, it shows the channel in question, and I can watch it in the browser. But it does not show in the guide on my Channels DVR on my tv. I have selected "All Channels" in the guide, but it does not show.
So basically, the guide in the server webpage in my browser shows correct, but it does not translate to my tv correctly.
Any ideas?
Many thanks,
Len
UPDATE - I cracked the code!
Everything depends upon how you configure the channels in each of the sources.
Once I hid the channel in the HDHomerun source, and made it a favorite in the Locast source, it showed properly in the guide.
Now I just wish Sling had more channels available in TVE.
