I have been using Hulu (TVE) as a tuner as well as an HDHomerun. Up until about a week ago, everything was fine. Now the program guide for the HDHomerun with the OTA channels is not working properly, very few shows appear. I tried reloading the EPG and it did not help. for example, all I see for 10:00AM on channel 15.1 (ABC) is "ABC @ 10AM" It says this for nearly all programs in the guide, the television network name followed by the time. Thanks.
Have same setup as you and no problems. Did you try removing the guide altogether and setting up again?
That fixed it. Thanks.
