I’m running the latest Android TV beta (85) on my Shield TV. Suddenly when I change the channel, the program info stays on the bottom of the screen rather than disappearing like it usually does. I can dismiss it manually by pressing up on my remote, so it’s not a huge deal, but every so slightly annoying.
Thanks, will fix.
Uploaded v86
You guys are ridiculously quick!!!
