I'm building a new version now with https support -- should be available to pull in a few minutes...
EDIT: Done and available to pull as :latest
I wish portainer would create volumes like a docker -v switch would. Would save so many headaches.
Are you absolutely sure this needs a preceding / ? I'm using the adbtuner docker example:
docker run -d --init -p 5592:5592 --name adbtuner -v adbtuner_config:/app/.config turtletank99/adbtuner
Bindings that look like this: adbtuner_config:/app/.config (with no slash) are docker volumes, and need to be defined in the volumes: section of a docker-compose. These are managed by Docker.
Bindings that look like this: /adbtuner_config:/app/.config (with a slash) are directory mappings, and are mapped to that exact directory on the docker host. These are not managed by Docker.
Some OS's don't allow new directories at the / level, and need to mapped a level down. Synology, for example, needs /volume1/data rather than just /data -- due to OS restrictions.
OK - that was the nudge i needed - all set!
One suggestion for your olivetin stack script - might suggest commenting out the 2nd DVR / DVR2 share lines, so that the vast majority only need cut/paste (similar to your external volume add-on).
Good suggestion -- I'll fix that now. What directory did you end up using for your HOST_DIR value?
I created a directory /Users/myusername/data and set to that
You and ChatGPT were thinking alike -- that was the suggestion there for the Mac.
@bnhf good stuff that you guys just added and I want to add Create a Chrome-Capture-for-Channels Stack in Portainert and getting exit status 3
The outlier is that I am not using docker desktop for Mac, I'm using something better. using Orbstack which is much gooder than docker:
anywho, here is the output from olive tin:
stdout
(empty)
stderr
exit status 3
+ dvr=192.168.1.30:8089
++ basename /config/cc4c.sh
+ extension=cc4c.sh
+ extension=cc4c
+ cp /config/cc4c.env /tmp
+ envFile=/tmp/cc4c.env
+ envVars=("TAG=$2" "HOST_PORT=$3" "HOST_VNC_PORT=$4" "VIDEO=$5" "AUDIO=$6" "TZ=$7" "HOST_VOLUME=$8")
+ printf '%s\n' TAG=latest HOST_PORT=5589 HOST_VNC_PORT=5900 VIDEO=9500000 AUDIO=192000 TZ=US/Mountain HOST_VOLUME=cc4c_config
+ sed -i /=#/d /tmp/cc4c.env
+ /config/portainerstack.sh cc4c
+ stackName=cc4c
+ portainerHost=
+ curl -s -o /dev/null http://:9000
+ portainerURL='https://:9443/api/stacks?type=2&method=string&endpointId=2'
+ portainerToken=
+ cp /config/cc4c.yaml /tmp
+ stackFile=/tmp/cc4c.yaml
++ grep DVR_SHARE= /tmp/cc4c.env
++ grep -v /
++ awk -F= '{print $2}'
+ dockerVolume=
++ grep VOL_EXTERNAL= /tmp/cc4c.env
++ grep -v '#'
+ volumeExternal=
++ grep VOL_NAME= /tmp/cc4c.env
++ grep -v '#'
+ volumeName=
+ [[ -n '' ]]
++ awk '{printf "%s\\n", $0}' /tmp/cc4c.yaml
++ sed 's/"/\\"/g'
+ stackContent='version: '\''3.9'\''\nservices:\n cc4c:\n image: fancybits/chrome-capture-for-channels:${TAG}\n container_name: cc4c\n command:\n - sh \n - -c \n - |\n Xvfb :99 -screen 0 1920x1080x16 &\n x11vnc -display :99 -forever &\n sed -i '\''/videoBitsPerSecond/c\ videoBitsPerSecond: process.env.VIDEO,'\'' main.js;\n sed -i '\''/audioBitsPerSecond/c\ audioBitsPerSecond: process.env.AUDIO,'\'' main.js;\n exec node main.js\n #devices:\n #- /dev/dri:/dev/dri # Uncomment for Intel Quick Sync (GPU) access\n ports:\n - ${HOST_PORT}:5589 # cc4c proxy port\n - ${HOST_VNC_PORT}:5900 # VNC port for entering credentials\n environment:\n - VIDEO=${VIDEO}\n - AUDIO=${AUDIO}\n - TZ=${TZ} # Add your timezone in the Environment variables section with \"name\" set to TZ and \"value\" to your local timezone\n volumes:\n - cc4c:/home/chrome # Creates persistent Docker Volume in /var/lib/docker/volumes for Chrome data and main.js\n restart: unless-stopped\nvolumes:\n cc4c:\n name: ${HOST_VOLUME}\n\n # Default Environment variables can be found below under stderr -- copy and paste into Portainer-Stacks Environment variables section in Advanced mode\n'
+ stackEnvVars='['
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},'
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},'
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},{"name": "HOST_VNC_PORT", "value": "5900"},'
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},{"name": "HOST_VNC_PORT", "value": "5900"},{"name": "VIDEO", "value": "9500000"},'
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},{"name": "HOST_VNC_PORT", "value": "5900"},{"name": "VIDEO", "value": "9500000"},{"name": "AUDIO", "value": "192000"},'
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},{"name": "HOST_VNC_PORT", "value": "5900"},{"name": "VIDEO", "value": "9500000"},{"name": "AUDIO", "value": "192000"},{"name": "TZ", "value": "US/Mountain"},'
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},{"name": "HOST_VNC_PORT", "value": "5900"},{"name": "VIDEO", "value": "9500000"},{"name": "AUDIO", "value": "192000"},{"name": "TZ", "value": "US/Mountain"},{"name": "HOST_VOLUME", "value": "cc4c_config"},'
+ IFS==
+ read -r key value
+ stackEnvVars='[{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},{"name": "HOST_VNC_PORT", "value": "5900"},{"name": "VIDEO", "value": "9500000"},{"name": "AUDIO", "value": "192000"},{"name": "TZ", "value": "US/Mountain"},{"name": "HOST_VOLUME", "value": "cc4c_config"}]'
++ cat
+ stackJSON='{
"Name": "cc4c",
"SwarmID": "",
"StackFileContent": "version: '\''3.9'\''\nservices:\n cc4c:\n image: fancybits/chrome-capture-for-channels:${TAG}\n container_name: cc4c\n command:\n - sh \n - -c \n - |\n Xvfb :99 -screen 0 1920x1080x16 &\n x11vnc -display :99 -forever &\n sed -i '\''/videoBitsPerSecond/c\ videoBitsPerSecond: process.env.VIDEO,'\'' main.js;\n sed -i '\''/audioBitsPerSecond/c\ audioBitsPerSecond: process.env.AUDIO,'\'' main.js;\n exec node main.js\n #devices:\n #- /dev/dri:/dev/dri # Uncomment for Intel Quick Sync (GPU) access\n ports:\n - ${HOST_PORT}:5589 # cc4c proxy port\n - ${HOST_VNC_PORT}:5900 # VNC port for entering credentials\n environment:\n - VIDEO=${VIDEO}\n - AUDIO=${AUDIO}\n - TZ=${TZ} # Add your timezone in the Environment variables section with \"name\" set to TZ and \"value\" to your local timezone\n volumes:\n - cc4c:/home/chrome # Creates persistent Docker Volume in /var/lib/docker/volumes for Chrome data and main.js\n restart: unless-stopped\nvolumes:\n cc4c:\n name: ${HOST_VOLUME}\n\n # Default Environment variables can be found below under stderr -- copy and paste into Portainer-Stacks Environment variables section in Advanced mode\n",
"Env": [{"name": "TAG", "value": "latest"},{"name": "HOST_PORT", "value": "5589"},{"name": "HOST_VNC_PORT", "value": "5900"},{"name": "VIDEO", "value": "9500000"},{"name": "AUDIO", "value": "192000"},{"name": "TZ", "value": "US/Mountain"},{"name": "HOST_VOLUME", "value": "cc4c_config"}]
+ curl -k -X POST -H 'Content-Type: application/json' -H 'X-API-Key: ' -d '{
"Name": "cc4c",
"SwarmID": "",
}' 'https://:9443/api/stacks?type=2&method=string&endpointId=2'
curl: (3) URL using bad/illegal format or missing URL
anything that stands out to you that you might tweak in order for it to work with orbstack? or maybe its something different or something else on my end.
thanks.
You need to select a choice from any dropdown in OliveTin -- nothing can be blank. Otherwise, you'll see the above.
yeah - deleted my post as i spotted that first.
Something is still off, though - i can't get the scripts to create source to work - they just hang for me
2024-03-30 13:12:55 level="info" msg="Before Parse Args" cmd="/config/pluto-for-channels.sh \"{{ dvr }}\" \"{{ TAG }}\" \"{{ HOST_PORT }}\" \"{{ PLUTO_PORT }}\" \"{{ PLUTO_CODE }}\" \"{{ CDVR_STARTING_CHANNEL }}\""
2024-03-30 13:12:55 level="info" msg="After Parse Args" cmd="/config/pluto-for-channels.sh \"myrealhostname:8089\" \"latest\" \"7780\" \"7777\" \"local,us_east\" \"4500\""
2024-03-30 13:12:55 level="info" msg="Action starting" timeout="40" title="Create a Pluto-for-Channels Stack in Portainer + CDVR Custom Channels"
...and nothing ever comes back. Tried on a couple of sources too.
Are you getting anything in stdout or stderr if you wait for the timeout? It's set to 40 seconds, but it's probably more like 80 seconds in reality.
They don't even show up as entries in the logs tab on olivetin - I'm only grabbing the above snippet from the docker container.
Weird. If you exec into the container, using the Portainer "Quick Actions" button for that purpose, are you seeing a whole bunch of scripts in /config?
Post the results of ls -la /config here please.
total 604
drwxr-xr-x 111 root root 3552 Mar 30 13:00 .
drwxr-xr-x 1 root root 4096 Mar 30 12:22 ..
-rwxr-xr-x 1 root root 73 Mar 30 12:22 adbtuner.env
-rwxr-xr-x 1 root root 1205 Mar 30 12:22 adbtuner.sh
-rwxr-xr-x 1 root root 861 Mar 30 12:22 adbtuner.yaml
-rwxr-xr-x 1 root root 550 Mar 30 12:22 ah4c.env
-rwxr-xr-x 1 root root 1683 Mar 30 12:22 ah4c.sh
-rwxr-xr-x 1 root root 3715 Mar 30 12:22 ah4c.yaml
-rwxr-xr-x 1 root root 111 Mar 30 12:22 cc4c.env
-rwxr-xr-x 1 root root 353 Mar 30 12:22 cc4c.sh
-rwxr-xr-x 1 root root 1213 Mar 30 12:22 cc4c.yaml
-rwxr-xr-x 1 root root 348 Mar 30 12:22 ccextractor.sh
-rwxr-xr-x 1 root root 11244 Mar 30 12:22 cdvr_movie_library_to_csv.py
-rwxr-xr-x 1 root root 381 Mar 30 12:22 cdvr_movie_library_to_csv.sh
-rw------- 1 root root 18082 Mar 30 12:59 channels_dvr_channel_list_20240330_125939.csv
-rwxr-xr-x 1 root root 36373 Mar 30 12:22 channels_dvr_monitor_channels.py
-rwxr-xr-x 1 root root 4137 Mar 30 12:22 channels_dvr_monitor_channels.sh
-rwxr-xr-x 1 root root 13735 Mar 30 12:22 channels_to_csv.py
-rwxr-xr-x 1 root root 377 Mar 30 12:22 channels_to_csv.sh
-rwxr-xr-x 1 root root 881 Mar 30 12:22 channels_to_csv_awk.sh
-rwxr-xr-x 1 root root 110 Mar 30 12:22 comskipignore.sh
-rwxr-xr-x 1 root root 2555 Mar 30 12:22 comskipini.sh
-rwxr-xr-x 1 root root 63618 Mar 30 12:22 config.yaml
drwxr-xr-x 2 root root 64 Mar 30 12:19 data
-rwxr-xr-x 1 root root 1383 Mar 30 12:22 deletelogs.sh
-rwxr-xr-x 1 root root 145 Mar 30 12:22 dockercompose.sh
-rwxr-xr-x 1 root root 733 Mar 30 12:22 edlstrip.sh
-rwxr-xr-x 1 root root 519 Mar 30 12:22 eplustv.env
-rwxr-xr-x 1 root root 1595 Mar 30 12:22 eplustv.sh
-rwxr-xr-x 1 root root 3038 Mar 30 12:22 eplustv.yaml
-rwxr-xr-x 1 root root 417 Mar 30 12:22 fifopipe_containerside.sh
-rwxr-xr-x 1 root root 1850 Mar 30 12:22 fifopipe_hostside.sh
-rwxr-xr-x 1 root root 72 Mar 30 12:22 filebot.env
-rwxr-xr-x 1 root root 354 Mar 30 12:22 filebot.sh
-rwxr-xr-x 1 root root 843 Mar 30 12:22 filebot.yaml
-rwxr-xr-x 1 root root 770 Mar 30 12:22 fix_thumbnails.rb
-rwxr-xr-x 1 root root 968 Mar 30 12:22 fix_thumbnails.sh
-rwxr-xr-x 1 root root 4288 Mar 30 12:22 foreground.sh
-rwxr-xr-x 1 root root 126 Mar 30 12:22 frndlytv-for-channels.env
-rwxr-xr-x 1 root root 2013 Mar 30 12:22 frndlytv-for-channels.sh
-rwxr-xr-x 1 root root 909 Mar 30 12:22 frndlytv-for-channels.yaml
-rwxr-xr-x 1 root root 4884 Mar 30 12:22 generatem3u.sh
-rwxr-xr-x 1 root root 6815 Mar 30 12:22 healthcheck.sh
-rwxr-xr-x 1 root root 814 Mar 30 12:22 healthcheck_stack.sh
-rwxr-xr-x 1 root root 5539 Mar 30 12:22 healthcheck_wsl.sh
-rwxr-xr-x 1 root root 4321 Mar 30 12:22 ical_2_xmltv.py
-rwxr-xr-x 1 root root 1013 Mar 30 12:22 ical_2_xmltv.sh
-rw-r--r-- 1 root root 36 Mar 30 12:19 installation-id.txt
-rwxr-xr-x 1 root root 408 Mar 30 12:22 listcomskipignore.sh
-rwxr-xr-x 1 root root 1055 Mar 30 12:22 llc2metadata.sh
-rwxr-xr-x 1 root root 879 Mar 30 12:22 logfilter.sh
-rwxr-xr-x 1 root root 1414 Mar 30 12:22 manualrecordings.sh
-rwxr-xr-x 1 root root 741 Mar 30 12:22 markforrerecord.sh
-rwxr-xr-x 1 root root 642 Mar 30 12:22 marknocommercials.sh
-rwxr-xr-x 1 root root 72 Mar 30 12:22 mediainfo.env
-rwxr-xr-x 1 root root 354 Mar 30 12:22 mediainfo.sh
-rwxr-xr-x 1 root root 924 Mar 30 12:22 mediainfo.yaml
-rwxr-xr-x 1 root root 436 Mar 30 12:22 mlb.tv-for-channels.env
-rwxr-xr-x 1 root root 1304 Mar 30 12:22 mlb.tv-for-channels.sh
-rwxr-xr-x 1 root root 3819 Mar 30 12:22 mlb.tv-for-channels.yaml
-rwxr-xr-x 1 root root 475 Mar 30 12:22 notifications.sh
-rwxr-xr-x 1 root root 312 Mar 30 12:22 olivetin-for-channels.env
-rwxr-xr-x 1 root root 2146 Mar 30 12:22 olivetin-for-channels.yaml
-rwxr-xr-x 1 root root 54 Mar 30 12:22 organizr.env
-rwxr-xr-x 1 root root 300 Mar 30 12:22 organizr.sh
-rwxr-xr-x 1 root root 466 Mar 30 12:22 organizr.yaml
-rwxr-xr-x 1 root root 826 Mar 30 12:22 pingcdvr.sh
-rwxr-xr-x 1 root root 1366 Mar 30 12:22 playonedl.sh
-rwxr-xr-x 1 root root 41 Mar 30 12:22 plex-for-channels.env
-rwxr-xr-x 1 root root 1343 Mar 30 12:22 plex-for-channels.sh
-rwxr-xr-x 1 root root 606 Mar 30 12:22 plex-for-channels.yaml
-rwxr-xr-x 1 root root 1801 Mar 30 12:22 plexiptv.sh
-rwxr-xr-x 1 root root 2313 Mar 30 12:22 plextoken.sh
-rwxr-xr-x 1 root root 81 Mar 30 12:22 pluto-for-channels.env
-rwxr-xr-x 1 root root 1356 Mar 30 12:22 pluto-for-channels.sh
-rwxr-xr-x 1 root root 933 Mar 30 12:22 pluto-for-channels.yaml
-rwxr-xr-x 1 root root 26 Mar 30 12:22 pluto.env
-rwxr-xr-x 1 root root 217 Mar 30 12:22 pluto.sh
-rwxr-xr-x 1 root root 521 Mar 30 12:22 pluto.yaml
-rwxr-xr-x 1 root root 1469 Mar 30 12:22 portainerstack.sh
-rwxr-xr-x 1 root root 142 Mar 30 12:22 removecomskipignore.sh
-rwxr-xr-x 1 root root 374 Mar 30 12:22 restartshutdown.sh
-rw-r--r-- 1 root root 17595 Mar 30 12:59 robsm2mini-8089_channel_list_latest.csv
-rw-r--r-- 1 root root 1530 Mar 30 13:00 robsm2mini-8089_healthcheck-olivetin_latest.log
-rwxr-xr-x 1 root root 26 Mar 30 12:22 samsung-tvplus-for-channels.env
-rwxr-xr-x 1 root root 1303 Mar 30 12:22 samsung-tvplus-for-channels.sh
-rwxr-xr-x 1 root root 693 Mar 30 12:22 samsung-tvplus-for-channels.yaml
-rwxr-xr-x 1 root root 88 Mar 30 12:22 scanlocalcontent.sh
-rwxr-xr-x 1 root root 136 Mar 30 12:22 setcomskipignore.sh
-rwxr-xr-x 1 root root 330 Mar 30 12:22 stationid.sh
-rwxr-xr-x 1 root root 26 Mar 30 12:22 stirr-for-channels.env
-rwxr-xr-x 1 root root 1291 Mar 30 12:22 stirr-for-channels.sh
-rwxr-xr-x 1 root root 669 Mar 30 12:22 stirr-for-channels.yaml
-rwxr-xr-x 1 root root 133 Mar 30 12:22 tailscale.env
-rwxr-xr-x 1 root root 269 Mar 30 12:22 tailscale.sh
-rwxr-xr-x 1 root root 1266 Mar 30 12:22 tailscale.yaml
-rwxr-xr-x 1 root root 41 Mar 30 12:22 tubi-for-channels.env
-rwxr-xr-x 1 root root 1299 Mar 30 12:22 tubi-for-channels.sh
-rwxr-xr-x 1 root root 606 Mar 30 12:22 tubi-for-channels.yaml
-rwxr-xr-x 1 root root 119 Mar 30 12:22 vlc-bridge-fubo.env
-rwxr-xr-x 1 root root 265 Mar 30 12:22 vlc-bridge-fubo.sh
-rwxr-xr-x 1 root root 765 Mar 30 12:22 vlc-bridge-fubo.yaml
-rwxr-xr-x 1 root root 41 Mar 30 12:22 vlc-bridge-pbs.env
-rwxr-xr-x 1 root root 1284 Mar 30 12:22 vlc-bridge-pbs.sh
-rwxr-xr-x 1 root root 392 Mar 30 12:22 vlc-bridge-pbs.yaml
-rwxr-xr-x 1 root root 80 Mar 30 12:22 vlc-bridge-uk.env
-rwxr-xr-x 1 root root 1330 Mar 30 12:22 vlc-bridge-uk.sh
-rwxr-xr-x 1 root root 430 Mar 30 12:22 vlc-bridge-uk.yaml
-rwxr-xr-x 1 root root 35 Mar 30 12:22 watchtower.env
-rwxr-xr-x 1 root root 288 Mar 30 12:22 watchtower.sh
-rwxr-xr-x 1 root root 536 Mar 30 12:22 watchtower.yaml
Looks like everything's there. Let's see if we can get a better idea of what's happening. From that same exec command prompt run:
/config/pluto-for-channels.sh "myrealhostname:8089" "latest" "7780" "7777" "local,us_east" "4500"
Hopefully there will be some debug output, and if so post it here.
EDIT: Don't use plex-for-channels for testing -- it's slow (about 6 minutes per region before the M3U URL is made available by that container) -- all the others are pretty quick though in my testing.
It looks like it's failing to pass in the hostname - an endless string of:
+ curl -s -o /dev/null http://:7780
+ [[ -n '' ]]
I tried pluto and samsung - no worries there
Did you add the two new OliveTin env vars, as described at the end of the first post in this thread? PORTAINER_TOKEN and PORTAINER_HOST?
yep.
Pasted from the stack editor:
PORTAINER_TOKEN=gobblygook
PORTAINER_HOST=correcthostname
And are they defined in the environment section of the docker-compose like so:
environment:
- CHANNELS_DVR=${CHANNELS_DVR} # Add your Channels DVR server in the form hostname:port or ip:port
- CHANNELS_DVR_ALTERNATES=${CHANNELS_DVR_ALTERNATES} # Space separated list of alternate Channels DVR servers to choose from in the form hostname:port or ip:port
- CHANNELS_CLIENTS=${CHANNELS_CLIENTS} # Space separated list of Channels DVR clients you'd like notifications sent to in the form hostname or IP
- UPDATE_YAMLS=${UPDATE_YAMLS} # Set this to true to update config.yaml
- UPDATE_SCRIPTS=${UPDATE_SCRIPTS} # Set this to true to update all included scripts
- PORTAINER_TOKEN=${PORTAINER_TOKEN} # Generate via <username> dropdown (upper right of WebUI), "My account", API tokens
- PORTAINER_HOST=${PORTAINER_HOST} # Hostname or IP of the Docker host you're running Portainer on.
