Project One-Click: All-in-One Installations of Docker Extensions and CDVR Custom Channels
I don't get either number when I hover over "environments." Rather, I get localhost:9000/#!/endpoints
Did I fix my posts correctly above?
This needs to be done from the page shown in the screenshot. Click on Home in Portainer, and then hover over the local environment block.
Way better -- thanks! :slight_smile:
I get the number "2"
Check if you're using the latest OliveTin Docker Compose (as shown in Post #1 of this thread), and check if your env vars include the new:
PORTAINER_ENV=2
If not, add it.
I think I know what to do, but I cannot remember where in Portainer to go to change the variables.
The OliveTin Docker Compose does not get automatically updated, and I generally only change it a few times per year. Here's the latest one from post #1 (dated 2025.02.25):
version: '3.9'
services:
  olivetin: # This docker-compose typically requires no editing. Use the Environment variables section of Portainer to set your values.
    # 2025.02.25
    # GitHub home for this project: https://github.com/bnhf/OliveTin.
    # Docker container home for this project with setup instructions: https://hub.docker.com/repository/docker/bnhf/olivetin.
    image: bnhf/olivetin:${TAG} # Add the tag like latest or test to the environment variables below.
    container_name: olivetin
    hostname: olivetin
    dns_search: ${DOMAIN} # For Tailscale users using Magic DNS, add your Tailnet (tailxxxxx.ts.net) to use hostnames for remote nodes, otherwise use your local domain name.
    ports:
      - ${HOST_PORT}:1337
    environment:
      - CHANNELS_DVR=${CHANNELS_DVR_HOST}:${CHANNELS_DVR_PORT} # Add your Channels DVR server in the form CHANNELS_DVR_HOST=<hostname or ip> and CHANNELS_DVR_PORT=<port>.
      #- CHANNELS_DVR_ALTERNATES=${CHANNELS_DVR2_HOST}:${CHANNELS_DVR2_PORT} # Space separated list of alternate Channels DVR servers to choose from in the form hostname:port or ip:port.
      - CHANNELS_CLIENTS=${CHANNELS_CLIENTS} # Space separated list of Channels DVR clients you'd like notifications sent to in the form hostname or IP.
      - ALERT_SMTP_SERVER=${ALERT_SMTP_SERVER} # SMTP server to use for sending alert e-mails. smtp.gmail.com:587 for example.
      - ALERT_EMAIL_FROM=${ALERT_EMAIL_FROM} # Sender address for alert e-mails.
      - ALERT_EMAIL_PASS=${ALERT_EMAIL_PASS} # SMTP "app" password established through GMail or Yahoo Mail. Do not use your everyday e-mail address.
      - ALERT_EMAIL_TO=${ALERT_EMAIL_TO} # Recipient address for alert e-mails.
      - UPDATE_YAMLS=${UPDATE_YAMLS} # Set this to true to update config.yaml.
      - UPDATE_SCRIPTS=${UPDATE_SCRIPTS} # Set this to true to update all included scripts.
      - TZ=${TZ} # Add your local timezone in standard linux format. E.G. US/Eastern, US/Central, US/Mountain, US/Pacific, etc.
      - PORTAINER_TOKEN=${PORTAINER_TOKEN} # Generate via <username> dropdown (upper right of WebUI), "My account", API tokens.
      - PORTAINER_HOST=${PORTAINER_HOST} # Hostname or IP of the Docker host you're running Portainer on.
      - PORTAINER_PORT=${PORTAINER_PORT} # https port you're running Portainer on. 9443 is the default.
      - PORTAINER_ENV=${PORTAINER_ENV} # Set this is if you're using an alternate Portainer Environment for some reason. 2 is the default.
    volumes:
      - ${HOST_DIR}/olivetin:/config # Add the parent directory on your Docker you'd like to use.
      - ${DVR_SHARE}:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT} # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR network share.
      - ${LOGS_SHARE}:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}_logs # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR logs network share.
      #- ${TUBEARCHIVIST_SHARE}:/mnt/${CHANNELS_DVR_HOST}-${CHANNELS_DVR_PORT}_ta # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
      #- ${DVR2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT} # Note that these volume mounts should always be to /mnt/hostname-port or /mnt/ip-port (dash rather than a colon between).
      #- ${LOGS2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_logs # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your Channels DVR logs network share.
      #- ${TUBEARCHIVIST2_SHARE}:/mnt/${CHANNELS_DVR2_HOST}-${CHANNELS_DVR2_PORT}_ta # This can either be a Docker volume or a host directory that's connected via Samba or NFS to your TubeArchivist videos network share.
      - /var/run/docker.sock:/var/run/docker.sock
    restart: unless-stopped
  static-file-server:
    image: halverneus/static-file-server:latest
    container_name: static-file-server
    ports:
      - ${HOST_SFS_PORT}:8080
    environment:
      - FOLDER=${FOLDER}
    volumes:
      - ${HOST_DIR}/olivetin/data:${FOLDER}
#volumes: # use this section if you've setup a docker volume named channels-dvr, with CIFS or NFS, to bind to /mnt/dvr inside the container. Set ${HOST_DIR} to channels-dvr (HOST_DIR=channels_dvr) in that example.
  #channels-dvr:
    #external: true
  #channels-dvr-logs:
    #external: true
  #tubearchivist:
    #external: true
And, the sample env vars, which need to be updated with your values:
TAG=latest
DOMAIN=tailxxxxx.ts.net
HOST_PORT=1337
CHANNELS_DVR_HOST=local-server
CHANNELS_DVR_PORT=8089
CHANNELS_DVR2_HOST=another-server
CHANNELS_DVR2_PORT=8089
CHANNELS_CLIENTS=appletv4k-den firestick-bedroom
[email protected]
ALERT_EMAIL_PASS=xxxxxxxxxxxxxxxx
[email protected]
UPDATE_YAMLS=true
UPDATE_SCRIPTS=true
TZ=US/Mountain
HOST_DIR=/data
DVR_SHARE=/mnt/dvr
LOGS_SHARE=/mnt/channelsdvr
TUBEARCHIVIST_SHARE=/mnt/dvr
HOST_SFS_PORT=8080
FOLDER=/web
PORTAINER_TOKEN=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
PORTAINER_HOST=docker-host
PORTAINER_PORT=9443
PORTAINER_ENV=2
It's likely you only need to add the last one (PORTAINER_ENV=2) to your current list.
In Portainer-Stacks. Stop the OliveTin stack, and paste the new compose into the editor. Check the env vars and add PORTAINER_ENV.
I'm sorry but this does not make sense to me. I do not know how to get to the editor
Do I have to remember all of my previous variables for the new compose? I'm sorry to be such a pain but this is not easy for me.
I found what I think is an edit and added the portainer evv and 2 as the value. I get the same error for Plex
No, they'll be there. You're not deleting the stack, just modifying the existing one
That's the problem. I don't know where to edit. I know I've done it in the past but I've clicked on just about everything and cannot find where to add the latest compose
Update: I see where to duplicate/edit but there is nowhere to enter the compose
Update 2: I still cannot find where to add the new compose, but I have it set for latest. I was able to add PORTAINER_ENV with a value of 2, though. I reran the OliveTin for Plex and still get the same error.
Go into Portainer-Stacks and click on the OliveTin stack.
I does not give me the editor option. It says this stack was created outside of Portainer. Control over this stack is limited.
I googled the issue, and some say that my stack and container names should match. They do, though.
How did you do this if you weren't able to get into the stack editor?
I went to duplicate/edit and it had the area to add a value under ENV. Maybe that was the wrong place. I used to have the Editor to add the compose but now its gone.
That was the wrong place. I'll have to give this some thought, and get back to you later today.
Makes sense. Thank you.
Here is what I get when I go to the Stack:
I removed the wrong addition. Above is what I get when I go to the compose.
The duplicate/edit option is for containers not stacks. A stack is one or more containers spun-up using Docker compose. We're in some unchartered territory here, and I'm trying to figure out if there's a way to recover.
FYI, I added a Plex container through terminal. I believe it's the same one that you can add via OliveTin. So, everything is working well. It's weird that Portainer changed my access to limited, so I cannot make changes. I've researched a fix, but my knowledge base is too limited to understand how to fix it. I get the frustration you experts must feel when dealing with someone like me who has limited knowledge of how to do more than simple tasks with stacks and containers. I have the same frustration as an attorney explaining legal matters to my company. Anyway, thank you again for being so willing to help.
