Provider - Spectrum
I picked up one of the new Spectrum Xumo Stream boxes and I have been comparing it to the Apple TV. I have been very impressed, so far. It worked well over WiFi, but I connected it to Ethernet to give it a fair comparison with the similarly connected Apple TV. The old school style remote with numbers works great with the Spectrum app and the voice control has been accurate. Most all of the major apps are available and respond well.
If it had a Channels app, It would be a nice replacement for the Apple TV.
It does appear that Spectrum is going to be replacing the set top cable connected boxes with the Stream Box.
Spectrum TVE stopped working. Logs submitted cd21b587-ba69-4ad9-ba06-d4967cc87d4a
This is new to me. I re-entered password and rescanned channels.
2023/12/20 20:14:09.470050 [TVE] action=auth mvpd=Spectrum requestor=nbcentertainment
2023/12/20 20:14:10.601822 [TVE] action=version product=Chrome/120.0.6099.129 jsVersion=12.0.267.10 protocol=1.3 revision=@204016af461e03117aa3858b51ba4534c7cfda81
2023/12/20 20:14:10.620736 [TVE] action=page_ready chromeVersion=120
2023/12/20 20:14:10.621463 [TVE] action=navigate url=https://sp.auth.adobe.com/adobe-services/authenticate/saml?noflash=true&mso_id=Spectrum&requestor_id=nbcentertainment&no_iframe=true&domain_name=adobe.com&redirect_url=https%3A%2F%2Fsp.auth.adobe.com%2Fadobe-services%2FcompletePassiveAuthentication
2023/12/20 20:14:10.624351 [TVE] action=request type=Document method=GET url=https://sp.auth.adobe.com/adobe-services/authenticate/saml
2023/12/20 20:14:10.836817 [TVE] action=wait_for_page
2023/12/20 20:14:10.867313 [TVE] action=request type=Document method=POST url=https://tve.spectrum.net/openam/SSOPOST/metaAlias/charter/idp
2023/12/20 20:14:10.867373 [TVE] action=auth_domain domain=tve.spectrum.net
2023/12/20 20:14:17.444242 [TVE] action=page_ready
2023/12/20 20:14:17.444318 [TVE] action=wait_for_page done=true reason=page_ready
2023/12/20 20:14:17.444387 [TVE] action=wait_for_auth timeout=30s
2023/12/20 20:14:17.444422 [TVE] action=fill_form u=xxxxxxxxx
2023/12/20 20:14:17.449560 [TVE] action=tvejs msg="spectrumLogin"
2023/12/20 20:14:17.449857 [TVE] action=fill_form state=done err=&runtime.ExceptionDetails{ExceptionID:1, Text:"Uncaught (in promise) ReferenceError: reactValueSet is not defined", LineNumber:69, ColumnNumber:3, ScriptID:"12", URL:"", StackTrace:(*runtime.StackTrace)(0xc001215f80), Exception:(*runtime.RemoteObject)(0xc00348e7e0), ExecutionContextID:0, ExceptionMetaData:easyjson.RawMessage(nil)}
2023/12/20 20:14:17.449963 [TVE] action=screenshot
2023/12/20 20:14:17.616087 [TVE] action=screenshot size=90019
2023/12/20 20:14:17.616507 [TVE] action=capture_html
2023/12/20 20:14:17.621805 [TVE] action=capture_html size=123535
2023/12/20 20:14:17.622355 [TVE] action=script_error err=ReferenceError: reactValueSet is not defined
    at spectrumLogin (auth_fill_form.js:69:3)
    at fill_form (auth_fill_form.js:498:11)
    at auth.js:1:11
2023/12/20 20:14:17.931898 [ERR] Could not start stream for TVE-Spectrum ch6046 LIFETIME: TVE: ReferenceError: reactValueSet is not defined
    at auth.js:1:11
Upgrade to the pre-relleases and see if that helps.
click support>troubshoot and Check for latest CHrome release.
Sorry about this. There's a new pre-release coming out in the next 10 minutes or so with the fix for this.
This is on latest, but looks like they are aware.
This should resolve the issue.
It fixed it. Thanks for the quick turnaround.
I am running latest stable release 2024.01.08.1431 and as of this morning, cannot play any Discovery channels using TVE with provider Spectrum. I'm getting 'Tuner Unreachable' message. Anyone else? Thanks
None of the Discovery Networks are playing today.
No login form
Directv Stream
Just tried the discovery channel from TVE source and it started just fine for me. Could be that my auth token is just still active and it didn't need to re-authorize.
Tried Discover, TNT, HGTV and all worked for me. YouTubeTV TVE Source
Pretty sure the users having an issue are having to re-auth the channels after their tokens expire (every 7 days for Discovery Network Channels using Xfinity)
Just to close the loop, I think I was having a password issue. I changed it, updated for my Spectrum source, and had to rescan discovery channels and now all is good! I also moved to the latest pre-release, 2024.01.30.0358, but that was probably not necessary. Thanks all.
Is there a list of spectrum channels that support TVE to use in Channels DVR?
@turfitgolf
Does this help?
https://getchannels.com/docs/channels-dvr-server/tv-everywhere/availability/#Spectrum
Blink once for Yes, twice for No :laughing:
I don't have a Spectrum sub any longer, but if someone here did and they were willing, they could kick out a quick Excel spreadsheet for you based on this:
Has anyone had experience using Spectrum TV Stream with Channels DVR?
I've been using Spectrum TV Choice for the last year and have had no problems, but that's because I thought it was the only way to get TCM. Turns out that's not the case. So I could definitely save money if Spectrum TV Stream fills the bill.
I am having an issue setting up tv everywhere with spectrum. I use my id and pw - which I can log into spectrum online to watch tv but when I put it in channels - it errors out. Same thing happens if I try Philo, but philo has a weird log in so I can work on that later but would love to get Spectrum step up
Is Spectrum TVE working for everyone? I’m getting a lot of inconsistencies. Most channels work on their TVE website such as C Span but I get an error under Channels. https://sp.auth.adobe.com/adobe-services/session: 401 Unauthorized: "Data not foundā€
CNN consistently goes out on both Channels and their TVE website.
Any thoughts?
It’s not working for me either. Channels is able to get the stream but it never gets past the default ā€˜commercial’. For instance, ESPN shows the ESPN logo that it does when there isn’t a streaming commercial. Other channels give a stream is currently experiencing an issue screen.
I thought I had figured it out when I launched Chrome and tried TVE directly in the browser. I got a message that indicated Chrome was out of date. I updated Chrome. Restarted my Mac and no luck.
I’ve tried updating Channels to the latest pre-release. Updating my Spectrum credentials. Rescanning. Removing and re-adding the Spectrum TVE source.
Nothing works. Channels seems to think it’s tuned the channel, but it isn’t quite tuning it.
