Provider - Verizon Fios
Does anyone know if ATT Sportsnet Pittsburgh works with TV Everywhere? I would like to watch hockey games
Does anyone here know if NBC Sports Philly + works with fios? NBC Sports Philly regular does but I do not see plus.
Can you watch on their website?
Somehow no? Works completely fine on my TV though. Very strange.
Even stranger, it does work with my Boston based Xfinity Campus login, but that's no good for ChannelsDVR.
I guess I can contact verizon and see what they say. I definitely pay for the channel.
Issue with fios - haven't had problems in forever - on most recent beta
This is after removing fios and readding
Anyone having issues with Cartoon Network on FIOS in Philly?
All my other channels seem ok, but i get "Failed: Could not start stream on channels=[6041]: TVE: Could not fetch playlist from turnerlive.warner...."
See this thread
Yeah, i saw that thread, but this is during the day with scheduled recordings (and right now, 10:22 am eastern, when scooby doo should be on)
I also just logged in via Verizon & was able to watch it, so it does not seem to be Cartoon Network being offline.
Is anyone having auth issues on fios?
Are they locking out accounts?
Every channel is failing with - Channel scan 10/182 MTVP failed: mtvn cAccessToken: Cable provider authentication failed
Anyone else seeing something either way?
I can't access anything any longer on FIOS. I get these error messages:
What should I do? This only just happened and I've updated to most recent version using my Synology.
If you just updated, I'd delete and re-add the account to Channels to see if that works
Thanks. That worked.
fios wasn't working so i deleted it and tried to readd
getting this on initial login
This is happening on two different servers with completely different networks and dns setups
Do you see the same banner when using a browser to Link your Provider and watch at nbc?
Is it blocking you, where you have to click the close button before you can finish entering your username and password?
So uh my wife killed our fios back to just local channels without letting me know
I think i found the reason :rofl:
Well...there you go :sweat_smile:
I am having problems with FIOS again. I deleted and then tried to re-add the account to channels.
I get the error " Cable provider authentication failed".
I can log into FIOS online using my credentials using my browser, but when I try to add them into Channels I get this error message.
What can I do?
