Did my every few days password change, remove and re-add to prevent issues, and stumbled on something. Manually rescanning any of the discovery networks channels comes up with 'not in subscription' even after just removing and re-adding Xfinity. Other channels (non discovery networks) rescan and work. So it seems like the only time those channels work is right after the initial channel scan from adding Xfinity. A manual rescan of one of the channels will break it. It's not a time period before they stop working, or watching where we login on what, this seems like it's not related to any passwords, what we're doing, etc because it never reauthorizes with a manual channel scan ever. Only with the initial scan. Can whatever is being done during that scan be implemented for when it needs to reauthorize?
I think they did
After you add the source and rescan any missing channels, delete the chromedata folder.
When a channel needs reauthed it recreates that folder automatically.
Then delete the folder again. No need to remove and readd the TVE source.
See this
and this
Nobody is replying, so the only way I'll know is when it happens again.
Speaking of XFINITY is there a way to do a full rescan of the comcast source through CLI ?
By deleting a chromedata folder and rescanning TVE source gave me some channels that said not in subscription before like Hallmark Drama.
@tmm1 .. Is there a way to force a full rescan of the TVE source using CLI in windows.
So where is the Chromedata folder at
It's where Channels DVR installs its runtime code on your DVR server.
Search the DVR log for 'Starting Channels DVR'
2021/07/12 15:17:19.748423 [SYS] Starting Channels DVR v2021.07.12.1959 (linux-x86_64 pid:7) in /channels-dvr/data
In my case '/channels-dvr/data' is a mount within the docker container that maps to a directory on my NAS.
The chromedata folder is in that data folder '/channels-dvr/data/chromedata'
/data/data/com.getchannels.dvr/files/channels-dvr/data
Looks pretty generic so I would imagine that path will be the same for others using a shield. Now to get to it and poke around.
Would it be possible to setup a script to automatically delete the folder every day? I don'y know how to write the scripts, just know how to follow directions lol
Easy to do on Windows Runs as Admin .. not sure on others.
rmdir /Q /S "C:\ProgramData\ChannelsDVR\data\chromedata"
I stopped being able to see some channels again today (mainly Discovery based channels) via xfinity, so I deleted the chromedata folder, but it didn't work. before deleting, i was getting No Auth Token messages, after deleting (and restarting the channels server), I saw messages that were more verbose, like this channel is not authorized, etc.
I am fairly new to this TVE process. I currently have FUBO and an outside antenna wit HDHomerun. I have Comcast internet and FUBO. I am paying $76 for internet and 70 for FUBO. Comcast is offering me the same speed internet and 125 channels for two years for $80+taxes. As I understand it, I won't need any Comcast equipment to get Comcast on Channels (which I love). And it seems from reading that almost all of the Comcast TV channel will come in as TVE. If I am correct, the Comcast offer will save me a lot of money. Suggestions and help for a Newbie.
So without any equipment, I still have this service fee that you will most likely also have.
It would still save you some money by dropping fubo, in lieu of this new plan, but I'm thinking more in the $40 - $50 range and be aware that the Xfinity tve still has a few kinks and requires maintenance to keep all the channels working without any interruptions. That's all talked about in the Xfinity threads.
Are you not already using Channels DVR? If you are new to channels, next would be coming up with a server setup. It can run on plenty of different devices, computer, Nas, shield, and more so try to define your needs such as how many clients will you have potentially watching at once, how much do you think the maximum number of simultaneous recordings will be, how much storage space would you like, will you be using remote viewing, etc. That should all play into your decisions.
Yes I am using Channels. I have a DVR Server set up on an SSD computer. I love the commercial skipping.
So Comcast always finds a way to squeeze more $ out of you. In checking there is the Local Channel fee you refer to as Broadcast TV. They also charge an HD fee and a Technology fee whatever that is. So I have decided to keep my current setup as my son can use one of the three screens that FUBO provides along with Cloud DVR.
When Comcast make you an offer, you better check the fine print!
If you have Fubo, you don't need Comcast.
I'm seeing the same issue with Discovery, Food Network, Investigation Discovery, Cooking Channel, and more. I checked Food Network and don't see a place to sign in with Xfinity, but I do see an offer for Discovery+. Is it possible Discovery pulled all their networks from TVE in favor of Discovery+?
EDIT: Looks like Food Network content might require a separate subscription.
I am watching food network on XFINITY TVE at this moment no problem. Every Channel you mentioned above is working.. on XFINITY TVE.
Yes XFINITY is on there as a provider and works fine.
If I want to know what I can watch on TVE I go to XFINITY Stream and filer by tv2go.
Yes, that worked fine. It took me to an Xfinity page where it said I was signed in and authorized to watch, then took me back to Food network where I was able to watch programming. I tried individually re-scanning those channels with the same error result.
