Proxmox Packet Loss
Hi all,
Wondering if someone can help me with this or point me in the right direction.
I've recently started learning Proxmox and have started to migrate services from Windows to containers. Plex with transcoding capabilities is fine. However, I'm experiencing terrible packet loss and picture degradation with Channels DVR, watching HDHR channels.
I set Channels DVR up using a helper script, and added the passthrough for the iGPU (Hardware transcoding is available).
This is an example of what I see when I start streaming.
Note: /mnt/PlexMedia/DVR/Streaming is a CIFS share on my NAS.
2025/04/04 14:08:42.804034 [ENC] Starting encoder for ch2 in /mnt/PlexMedia/DVR/Streaming/ch2-dANY-ip192.168.1.88-3069596952/encoder-1-1168150514 at 1 (1.537678) (encoder=h264_vaapi, codec=h264, acodec=aac, resolution=576, deinterlacer=hardware, bitrate=9744, segment_size=0.01)
2025/04/04 14:08:42.878633 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 0, dts = 2403678395), dropping it.
2025/04/04 14:08:43.290251 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-1-h264-aac---9744-256-576-2-0--hardware-false-false-0.01-0:  [h264_vaapi @ 0x30e35b00] Buffering settings are ignored in AVBR RC mode.
2025/04/04 14:08:43.710499 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 1, dts = 2403662404), dropping it.
2025/04/04 14:08:44.403403 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 0, dts = 2403804395), dropping it.
2025/04/04 14:08:44.434975 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 1, dts = 2403748804), dropping it.
2025/04/04 14:08:46.161099 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 0, dts = 2403926795), dropping it.
2025/04/04 14:08:46.240575 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 1, dts = 2403889204), dropping it.
2025/04/04 14:08:46.720003 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 1, dts = 2403932404), dropping it.
2025/04/04 14:08:46.752185 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 0, dts = 2403977195), dropping it.
2025/04/04 14:08:46.951172 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 0, dts = 2404034795), dropping it.
2025/04/04 14:08:46.951197 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 1, dts = 2403975604), dropping it.
2025/04/04 14:08:47.436375 [HLS] ffmpeg: ch2-dANY-ip192.168.1.88-remux:  [mpegts @ 0x31e054c0] Packet corrupt (stream = 1, dts = 2404018804), dropping it.
2025/04/04 14:08:47.923927 [HLS] Stopping transcoder session ch2-dANY-ip192.168.1.88 (out=8.697689s finished=false first_seq=1 last_seq=5)
2025/04/04 14:08:47.936243 [TNR] Closed connection to 12526485/0 for ch2 BBC TWO
Any help is appreciated!
What are the specs on the system you're using? What resources did you allocate to the LXC? Screenshots of both might be helpful...
While you can over-allocate vCPUs on Proxmox, you cannot over-allocate RAM. Given your Proxmox host has less than 16GB RAM and 8 cores total, both of your allocations to CDVR are high -- though I don't think this is necessarily the problem here, I would still suggest adjustments downward.
How do you have your networking set up?
Sounds like more of a network issue than a container/provisioning issue.
I've just checked playing directly from the HDHR and I'm getting problems via VLC as well. I also found that we're having intermittent signal issues in the area due to some mobile traffic lights that have been placed right next to the communal aerial. It could actually be a source signal issue that's causing this.
To double check I've also tried using an IPTV source via channels and it seems to be transcoding fine.
Thanks for looking into this.
