New OliveTin-for-Channels pushed incorporating the latest 3.x version of this excellent script:
Thanks much for the new improved script!
Especially the persistent reference files that keep track of channels between runs/restarts.
Have a question regarding this
I don't see the duplicate channels called out, for instance in my Pluto source. Are they supposed to appear? I'm not doing text/email notifications as that's overkill for me. Just looking in the log file.
Using Channels DVR server at: http://192.168.1.4:8489.
Checking for channel lineup changes every 720 minutes.
Visual monitoring only, no email or text will be sent.
Last check : 2024-02-10 11:10:58
Server version: 2024.02.10.0353
Channels DVR server URL: http://192.168.1.4:8489
Channels DVR version: 2024.02.10.0353
New source with 391 channels: "Pluto"
See file /config/192.168.1.4-8489_data/Pluto.txt for the full lineup.
New source with 523 channels: "HDHomeRun PRIME"
See file /config/192.168.1.4-8489_data/HDHomeRun_PRIME.txt for the full lineup.
Next check: 2024-02-10 23:10:58
Here's what I'm seeing in media-server6-8089_channels_dvr_monitor_channels_latest.log:
Using Channels DVR server at: http://media-server6:8089.
Checking for channel lineup changes every 30 minutes.
An email will be sent to [email protected] when changes are detected.
Last check : 2024-02-10 09:44:55
Server version: 2024.02.08.0626
Channels DVR server URL: http://media-server6:8089
Channels DVR version: 2024.02.08.0626
Pluto TV: 390 channels (-1)
(http://htpc6:8183/playlist.m3u)
<--- Lineup changes (starting at 0) --->
! 2480 : NFL Channel (was Hot Bench)
- 2800 : NFL Channel
<--- Channel changes --->
- Hot Bench (2480)
<--- Duplicated channels --->
AspireTV Life: 262, 3220
BET Her: 2050, 258
BET Pluto TV: 2040, 256
Black Cinema: 130, 250
Black Classics: 254, 530
Black Throwbacks: 252, 320
CBS News Chicago: 2570, 5120
CBS News Colorado: 2540, 5130
CBS News Los Angeles: 2560, 5150
CBS News New York: 2550, 5180
Love & Hip Hop: 1690, 264
Vevo R&B: 266, 4730
XITE Gospel: 268, 4800
Sending email to [email protected]...
Message sent successfully!
Next check: 2024-02-10 10:14:55
Last check : 2024-02-10 10:14:56
No changes found in any source.
Next check: 2024-02-10 10:44:56
Last check : 2024-02-10 10:44:56
Next check: 2024-02-10 11:14:56
Last check : 2024-02-10 11:14:56
Next check: 2024-02-10 11:44:56
Last check : 2024-02-10 11:44:56
Next check: 2024-02-10 12:14:56
Last check : 2024-02-10 12:14:56
Next check: 2024-02-10 12:44:56
Last check : 2024-02-10 12:44:56
Next check: 2024-02-10 13:14:56
Checking every 30 minutes atm for "stress testing". I'm not doing PERSISTENT_LOGS though, so I'm not sure what my first run looked like anymore. @chDVRuser maybe shorten your interval for testing purposes, and see if the next run shows the dups?
Nope. Changed it to a 5 minute interval
Checking for channel lineup changes every 5 minutes.
Last check : 2024-02-10 12:26:22
Next check: 2024-02-10 12:31:22
Last check : 2024-02-10 12:31:23
Next check: 2024-02-10 12:36:23
Last check : 2024-02-10 12:36:23
Next check: 2024-02-10 12:41:23
Last check : 2024-02-10 12:41:23
Next check: 2024-02-10 12:46:23
Last check : 2024-02-10 12:46:24
Next check: 2024-02-10 12:51:24
Last check : 2024-02-10 12:51:24
Next check: 2024-02-10 12:56:24
@chDVRuser in the case where a new source is found, the script doesn't check the lineup itself, it just reports the new source and the number of channels
That's one thing I didn't think of.
Duplicated channels get reported only if a lineup has changed.
I can add it.
Ahh, thanks for the explanation.
No need to add it as I just wanted to make sure the log file contained the same detailed message that would be emailed. I'm over-notified of too many things and don't need text msgs/email that channel lineups have changed!
Text msg says check your email
Email says check a wesbite
Website says Check your secure messages
I had already logged in the Website and read the Secure message
Yes. Unless I made a mistake in the code, the contents of the log file and the email should be the same.
Is this from OliveTin? That's not from my script.
No. Just in general. Over Notified.
I see. Got it.
@bnhf and @chDVRuser
I got a change in my Pluto TV source today. I'm expecting that you should get it too.
I'm curious to get your feedback about the reported changes that you will see.
Looking good.
Picked up changes on two of my servers.
Channels DVR version: 2024.02.11.0311
Fubo bridge: 236 channels (-1)
(http://192.168.1.3:7777/fubo/playlist-hls.m3u)
<--- Lineup changes (starting at 9000) --->
- 9238 : CBS 4K
- CBS 4K (9238)
Big Ten Network Alternate: 9022, 9023, 9024
Pluto: 393 channels (+2)
(http://192.168.1.3:8080/playlist.m3u)
<--- Lineup changes (starting at 9001) --->
+ 9476 : Little House on the Prairie
+ Little House on the Prairie (9476)
+ She Wrote (9477)
AspireTV Life: 9363, 9454
BET Her: 9047, 9452
BET Pluto TV: 9046, 9451
Black Cinema: 9013, 9448
Black Classics: 9164, 9450
Black Throwbacks: 9149, 9449
CBS News Chicago: 9061, 9342
CBS News Los Angeles: 9060, 9345
CBS News New York: 9059, 9348
CBS News Sacramento: 9058, 9352
Love & Hip Hop: 9108, 9455
Vevo R&B: 9260, 9456
XITE Gospel: 9358, 9457
Great, @chDVRuser!
I'm curious about Big Ten Network Alternate on Fubo. Is that right that it appears 3 times on 3 consecutive channel numbers?
Are they different versions?
Also, it looks like the two examples that you posted came from the same server machine at 192.168.1.3.
How can it be that Fubo starts at 9000 and Pluto at 9001? That's not a bug in my script?
I can see that they are from two different dockers so maybe they are used by different Channels DVR servers?
I have everything on one machine so it was strange at first for me to wrap my head around your configuration. I'm guessing you have something like this:
The Big Ten alternates are different feeds, but typically only show different games during football season.
Here's mine copied from the e-mail notification:
Pluto TV: 392 channels (+2)
+ 640 : Little House on the Prairie
+ Little House on the Prairie (640)
+ She Wrote (690)
BET Her: 2050, 258
Vevo R&B: 266, 4730
Samsung TV Plus: 330 channels (+1)
(http://htpc6:8182/playlist.m3u)
<--- Lineup changes (starting at 1002) --->
- 1001 : Heartland
! 1002 : LOL! Network (was Ebony TV by Lionsgate)
! 1003 : Bring It! (was 60 Days In by A&E)
+ 1054 : EBONY TV by Lionsgate
+ 1058 : Heartland
+ 1122 : 60 Days In by A&E
+ 1207 : PBS Antiques Roadshow
- 1247 : Bring It!
! 1284 : FreeTV Estelar (was Tu Cine)
- 1325 : LOL! Network
+ EBONY TV by Lionsgate (1054)
- Ebony TV by Lionsgate (1002)
+ FreeTV Estelar (1284)
+ PBS Antiques Roadshow (1207)
- Tu Cine (1284)
FrndlyTV-noEPG: 6 channels (+1)
<--- Lineup changes (starting at 9657) --->
+ 9807 : Bounce
+ Bounce (9807)
Nice! So you got an email. That's good.
All the channel numbers (including starting numbers) are reported correctly?
192.168.1.3 is my old NAS which runs my docker sources like Pluto, Frndly, PBS, Fubo and some utility dockers.
192.168.1.4 is my new NAS that runs multiple Channels DVR servers in docker containers and one using the Synology package.
For all my m3u custom channel setups, I let Channels DVR assign the channel numbers.
I'm guessing it's Prefer channel-number from M3U, mine are set to Ignore channel-number from M3U
Guess it doesn't matter if you don't have passes preferring or ignoring channel numbers.
Thanks. I will change it and see if it makes a difference.
