Python script to be notified of channel lineup changes
And below is what I get with after reloading the Pluto source. It's looks like it's working very nicely!
Check time: 2024-05-31 09:54:47
Server version: 2024.05.26.0350
Channels DVR server URL: http://192.168.88.240:8089
Channels DVR version: 2024.05.26.0350
Pluto TV: 406 channels (+1)
(https://nocords.xyz/pluto/playlist.m3u)
<--- Lineup changes (starting at 0) --->
  • 4490 : Telemundo Noticias Noreste
<--- Channel changes --->
  • Telemundo Noticias Noreste (4490)
<--- Duplicated channels --->
CBS News Baltimore: 2540, 5070
CBS News Chicago: 2570, 5120
CBS News Los Angeles: 2560, 5150
CBS News New York: 2550, 5180
Pluto TV Cars: 0, 1560
Next check: 2024-05-31 10:09:47
Latest version (v3.3.0) of this script incorporated into OliveTin-for-Channels, and pushed as bnhf/olivetin:latest with all the usual OliveTin bells and whistles:
screenshot-htpc6-2024.05.31-11_38_21
Thanks, @bnhf
Let me know if you can figure out how to enable a start time.
I will be manually removing and adding the one server to check tomorrow.
I have it start at 11:05 and check every 12 hrs
I haven't had enough time yet to sit down and work on my code. :worried:
No rush. Just letting you know that when you do, I'll test it.
@chDVRuser I'm starting to think about adding a start time to my script.
In your case, would you want to be able to specify just a time or a combination of day + time?
Thanks, Just a 24hr time is fine. 00:00 - 23:59
I like checking mine after the daily morning guide fetch is done (09:00-11:00), but I have a few sources fetching the playlist and XMLTV using a cron job. Pluto is done every 2hrs and the fetch is done by 11:06, so that's when I have it checking my Pluto Server.
New release!
Version 3.4.0
[NEW] Added option '-s' to specify a start time in 24-hour format
@bnhf - The '-s' option is followed by HH:MM.
Example:
>python channels_dvr_monitor_channels.py -s 11:06
Script version 3.4.0
Using Channels DVR server at: http://127.0.0.1:8089.
The first check will be done when the current time is 11:06.
Checking for channel lineup changes every 30 minutes.
Visual monitoring only, no email or text will be sent.
Channel lineup changes will be written to:
C:\Users\mjitk\Documents\Scripts\test\127.0.0.1-8089_data\2024_channel_lineup_changes.log
The last activity will be saved in:
C:\Users\mjitk\Documents\Scripts\test\127.0.0.1-8089_data\last_activity.log
Current time: 22:16
Waiting for 12h 50m until the current time is 11:06...
If the option is not used, it will behave as we already know and start immediately.
@chDVRuser - Hopefully, this will work for you.
Thanks @mjitkop
When @bnhf adds it to OliveTin I will give it a try.
No rush, since I probably won't be able to do that until this weekend.
New bnhf/olivetin:latest (aka bnhf/olivetin:2024.07.17) pushed with version 3.4.0 of this script, along with required changes to the OliveTin Action launching it:
Thanks @mjitkop and @bnhf
Not at home, but I remoted in thru Tailscale, updated OliveTin, killed the old notifications and started them again using the scheduled start time option.
All looks good per the STD OUT. They should start later tonight. If any issues, I'll post back tomorrow.
Using Channels DVR server at: http://192.168.1.4:8489.
The first check will be done when the current time is 23:06.
Checking for channel lineup changes every 720 minutes.
/config/192.168.1.4-8489_data/2024_channel_lineup_changes.log
/config/192.168.1.4-8489_data/last_activity.log
Current time: 18:24
Waiting for 4h 42m until the current time is 23:06...
Background Channel Lineup Change Notifications process running for 192.168.1.4:8089
Background Channel Lineup Change Notifications process running for 192.168.1.4:8189
Background Channel Lineup Change Notifications process running for 192.168.1.4:8190
Background Channel Lineup Change Notifications process running for 192.168.1.4:8289
Background Channel Lineup Change Notifications process running for 192.168.1.4:8389
Background Channel Lineup Change Notifications process running for 192.168.1.4:8489
Looking good. Thanks @mjitkop and @bnhf
New bnhf/olivetin:latest (aka bnhf/olivetin:2025.01.31) pushed this morning with a new option for those using this project with e-mail notifications.
The OliveTin-for-Channels env vars of $ALERT_EMAIL_FROM, $ALERT_EMAIL_PASS and $ALERT_EMAIL_TO can now be used as values in the email, password and recipient fields respectively.
It would look like this, if you choose to use the option. However, the actual values can still be used as before:
I haven't been running mine for quite a while due to several reasons.
In particular, I haven't seen the transition to the new year.
@bnhf @chDVRuser
Was your log file updated to be 2025_channel_lineup_changes.log?
Yes:
Oh good, it worked. :tada:
Thank you for confirming. :slightly_smiling_face:
Yes
