May I ask how the relationship and working of the HDHR and Android TV work together. I am a HDHR fan but my cable company TDS tells me I cannot have a cable card with their new TDS+ system which is really jus Android /TIVO TV I would love to be able to use my HDHR again with all my subscribed channels. THANKS
It depends on your provider and if they provide TVE content. Channels does not interface with your cable like the HDHR does. It uses your login information to stream from the Networks' TVE sites. Not all channels provide a TVE stream and it can vary by provider if a channel is offered. My recommendation use the Channels free trial and see how it works with your setup.
You can also check to see what Channels DVR TVE channels you could get here
https://getchannels.com/docs/channels-dvr-server/tv-everywhere/availability/
Thank You for this information. Trying to decide if my HDHR is good for anything now.
Thank You
