Question about port forwarding
Is this correct for port forwarding for Channels DVR.
Is 192.168.0.53 the IP listed in the DVR UI under Basic Setup?
Yes, that is the IP address of the computer running Channels DVR.
That should be right, then.
You should ensure that the IP address of the Channels DVR is fixed and cannot be changed change via DHCP.
Thank you!
