Question about recording retention settings
When the Keep setting of a given Recording Pass is changed from All to Last "X" Only, at what point does the new retention setting apply? Also, at what point are out of scope recordings removed? Just trying to understand how the process works. Thanks in advance.
The cleanup process happens every few hours based on the new rules, at which point the recordings end up in Trash for a day or so depending on your settings.
Thank you!
