Looks like Quick Guide is not currently working on Android build 207.29.2200. It only shows the current channel. It works on regular (non-beta) version. Is this a known issue? I can take pics of the issue if needed. Tested on 3 devices (Nvidia Shield Pro, and 2 Android TVs (built-in to the TV)). Thanks!
Quick guide is working fine for me on my Chromecast Google TV running the current Beta 208.2.439, but I also force the Quick Guide to use my Favorites collection.
Oh, good point. I should be more specific. This is with the default settings. By default mine shows the adjacent channels on the guide data (OTA).
Normal Version:
Beta:
I might try those mustard donuts in the first cap. LOL.
There must be a settings mismatch, or different channels favorited in the apps.
What settings can I check? I'm just using the default settings. I don't use favorites. I just choose "All Channels" in the guide on both (beta, and normal).
There is a setting which controls what shows up in Quick Guide. The default is Favorites
Thanks! That was it! I found it under Settings | General | Live | Quick Guide. It was default to Favorites. Thanks again!
