Quick Guide Pull Down not updating
Server version 2026.10.24.0621
Apple TV Channels Beta 2026 build 11.13.349
I just added some virtual channels and made them part of my channel collection. They show in the main guide just fine, but they don’t appear in the correct spot in the quick guide (pull down guide) that appears at the top of my screen when I scroll down or use the down button.
The quick guide seems to only show what’s in my Favorites selections, not what’s in the channel collection that I’m currently viewing.
What the Quick Guide shows, is a setting. You may want to check your settings.
It's not very likely that server changes would effect this.
Have you been on the testflight version a while for the client, or did you just add it? It's possible the bug is there, but please check your settings first.
I’ve been on TestFlight for the client for a long time, no change there. I did, however, just start using channel collections. So the change there is what my quick guide now doesn’t match my guide.
Where are the quick guide settings that affect what it shows? I can’t seem to find what you’re referring to.
Settings > General > Live TV > Quick Guide
Found it, thank you!
Sweet, so was that the issue?
