Which thing is the "Quick Guide"?
In settings we have HD Channels set for the Quick Guide, but where exactly is that guide?
You can setup what we want on the "Navigation" menu, that works great!
But when you use the "Guide" from the navigation menu, you have that long list of options; All Channels, HD Channels, SD Channels, Favorites, etc. - Is that the Quick Guide? And if it is, why does it show All those options rather than just the HD Channels that I set it on in settings? Is there a way to get rid of this menu all together and ONLY have the HD channels when we use the guide?
