Quick question about remote settings
what's the difference between and when would i want to use each of
Manual versus auto
Are you talking about this in the DVR web admin UI?
UPNP (auto) or manually (manual) configured router port forwarding
There's a button Screenshot 2023-04-17 at 10-04-12 Channels Settings that takes you to this support article
Edited to correct thought to keyboard translation
Try automatic first. It it works, great. If not, try manual.
