Quick return to Live TV
Newby question: If I'm watching live TV channel, go to "Library" or "TV Shows" to check on something, is there a quick way (one button) to return to the live TV channel? Right now I am going back to Guide and clicking the show.
No
Okay, thanks.
Actually it may be possible if your remote has the colored red green yellow blue buttons using remote shortcuts and live tv. I can’t recall what exactly happens with the live tv choice. If it’s last channel or first channel in guide.
Using Google Chromecast, so no luck there - thanks though!
