In previous versions of Channels, you could quickly start watching a live channel by pressing on the channel logo from within the Guide view. The current version now brings up a list of Upcoming Shows/Movies for that channel instead.
I don’t find myself needing to access this Upcoming list very often/if at all, so having to swipe right to the current show title to start watching the channel feels like an extra step. With the Apple TV remote in particular its quite easy to overshoot the current show title, meaning you then need to swipe back to the left to make sure you’re on the current show before selecting. It all feels a bit clunky on Apple TV.
Would it be possible to add a setting to switch off the Upcoming Shows/Movies list from the Guide view so it reverts to the previous navigation of going directly to the live channel stream?
Or alternatively, could the default position of the remote’s selection highlight be the current show title rather than the channel logo column? That way you you’d eliminate the need to swipe right and could just swipe up/down and select.
