When I click on a radio station, there is a spinner while video stream is loading, but nothing happen.
It happens in all radio stations.
In VLC in computer, it works.
Please capture a stream sample using the http API and send it to us.
Capture a short sample video from http://HDHOMERUN:5004/auto/vCHANNEL?duration=15 and send it to [email protected]
For example, if your hdhomerun’s ip is 10.0.1.1 and the channel number having issues is 12, visit this URL in chrome: http://10.0.1.1:5004/auto/v12?duration=15
The problem still exists in the beta.
Sorry, I lost track of this issue.
I tried the sample you sent and it was working for me.
Can you submit diagnostics again in the app and select “video player” category.
I sent a diagnostic through the app.
Thanks.
Is channel 5008 (Gimmel) the radio station?
Yes.
Is there something new?
I was not able to reproduce any issue with your sample. Please send some more.
Also submit some more diagnostics from the Beta app again, but let the channel play for some time first.
Thanks for submitting more diagnostics.
It looks like the audio is playing, but it takes a long time to start- 30-40s. Do you hear it after waiting?
Yes. If I exit from the station, the app says:
This is the timeline:
I sent through the mail samples audio files of radio stations‏.
Thanks.
This issue has been fixed in the latest beta.
