Hello all,
I am trying to install on a Raspberry Pi 4 8GB in Docker through Portainer. I have tried the tve and arm64 tags. Neither works. The tve tag is a amd64 based image, so no surprise there. The OS for the Raspberry Pi is Ubuntu 64 bit. I am using the docker-compose.yml file found on the install page. The image downloads fine and begins to install.
The log only has one entry: "Running Channels DVR.."
Then it just sits there and no further progress. The container does not fully startup as I cannot log into it or reach it via the web server.
Anyone have this happen or have any suggestion on what I might be doing wrong?
Thank you!
