Raspberry PI and Docker/Channels
I am not so sure where to post this, if in correct I apologize. I currently run my Server on a Shield. I do access my movies off a WD cloud (ext2) but the DVR is on a mechanical hard drive on the shield. I run Docker on a Raspberry PI in order to populate some epg's such as Pluto. I want to move the DVR off the shield and the WD doesn't have the horsepower it seems. If I use the Channels image it will of course wipe out my Docker i stall. How can I run them both on my PI 4? Be kind I am new to Linux
You can setup dockers on the Pi image via ssh access
Ok, I tried that, and it need some sort of "key" access the PI via SSH- any chance you could point me to a link that might explain the process. Once I learn something I never forget :slight_smile: thanks
On a PC you have to generate the key with something like Putty
ok awesome thanks!
