Raspberry Pi DVR suddenly not found
I was using the Pi and updating Sources last night. Now today I cannot find it using dvr-server or dvr-server.local. What could have changed?
The green light is solid and seems to be functioning properly.
That's strange.
Does this work? http://192.168.1.233:8089
YEAH! Yes that works.
What changed?
There must be some bug with the hostname. I will check it out, but you can simply use the IP to access for now. The Channels app can also connect by IP: click Connect > At Home > 192.168.1.233
