I just used the latest server image to create a Raspberry Pi DVR. It came up just fine, but when I try to create a location for the DVR files, that user interface does not allow it. I get a no permission error.
I was using the /media/DVR folder, but after looking on the file system, it appears that the channel's user does not have permission to write into that directory. I tried setting the /media folder to 777 (chmod 777 media) and that works for a while, but the os seems to come around and change the permissions back to 755 and blows away the directories that were created by the DVR software.
What location should be used to create the main storage? The drive is 2TB, so there is a lot of room.
