My Rasberry Pi failed and will replace it, other than loading the boot image on the Pi will I need to do anything to the external USB drive that comtains all of my recordings? Hope to just plug my USB drive in and the new Pi boot off of it and be back to normal.
Rather than replace it, you may want to consider going with a beelink mini pc. They make great channels servers....
Which beelink mini PC do you recommend if the only need is for Channels DVR?
One with a n95 or n100 cpu.
