Re-index DVR folder
Hello,
I was having some issues with some shows not showing up, and some deleted shows still showing.
So I re-installed channels and wanted it to scan the TV folder fresh without using any cache. I thought it would act like the movies/tv import under local content and would scan the dvr/TV folder.
Unfortunately, it seems that channels is not scanning the folder and detecting the content it has previously recorded. As I wanted to start fresh since I was having some issues, I deleted the database backups.
How do I tell channels to scan and index the DVR folder? right now it is saying:
Stats
0 Passes
0 Shows
0 Recordings
Despite the DVR / TV folder containing a lot of TV Shows that channels has previously recorded
You don't. Move the content to the import folders.
Or restore a backup. See the docs for how to move the dvr
