Record live TV to HDHomerun connected drive
How do I set my recordings in Channels of live TV on the HD Home Run to record to the drive that's plugged into the HomeRun?
You can’t. That only works with silicon dust hdhr dvr software.
You unplug the drive from the HD Home Run and plug it into the computer running Channels DVR. This may be tricky if Channels DVR is running on a NAS yet it should be possible.
Yeah, I've been emailing with someone from Channels on this. They said:
You do it right in setting on Channels DVR Server. Visit settings, and there's a path to set. You'll need to disable the server first with the checkbox. Set the new directory, then re-enable the server.
However, when I disable the server, any ability to set a new directory or path goes away.
Pretty sure I got it.
Changed the path where blue arrow is pointing in screenshot.
