Hi devs, I'm using the HTTP API for a toggle record - is it expected behaviour to not record the selected programme on the guide using this toggle? Does it only work when tuned to a channel? Many thanks.
Yes, it only works while you are currently watching something.
Any mileage to change this behaviour?
Thanks for the reply. Alex
There's no plans to change this, as the purpose of the /record endpoint is to start recording what is currently being watched.
Understood - there's a few set top boxes here in the UK which do allow recording from the guide with a record button press that is all. It's nice and quick if you're using the guide, as I'm sure you can imagine, especially if the show isn't on yet.
