Have an episode I want to record from a pass and I know it will be airing next Monday Schedule - Outdoor Channel, but the Gracenote guide data shows the wrong episode. Since the guide is wrong, Channels DVR won't record it, thinking it's one it already recorded. If I select mark as not recorded, it will re-record the same old episode it already recorded tomorrow when it airs.
Just checking to see if there's a better way to do this, as I've previously used the curl manual recording method for this situation. I can manually select it from the grid guide to record, but that will record with the incorrect guide metadata currently listed.
Farming the Wild
SeriesID 15775579
Actual airing next Monday is Oregon USA Part 2, but it's listed as Oregon USA Part 1 which was already recorded.
And yes, I know I could always edit the recorded metadata after it records, but if you multiply this one example by the ones I encounter, it would be hard to remember why Channels DVR recorded the same episode twice until I remember what I did and what it says was recorded was wrong. With the manual curl recording method I set the metadata and artwork so the pass, scheduled recording and completed recording are correct, inluding the recording filename.
