Recording and scheduled job went missing
Shouldn't this at least show as failed in scheduled recordings?
Failures used to appear there. (maybe that was changed in v2023.05.07.0017?)
Nothing appears in calendar, scheduled jobs or recordings.
2023/05/08 19:00:00.005270 [DVR] Starting job 1683597600-614 Shepherds Chapel @ 7PM on ch=[3777]
2023/05/08 19:00:00.760071 [ERR] Failed to start stream on channel 3777 via M3U-ShepherdsChapel: M3U: Stream Not Available
2023/05/08 19:00:00.760126 [DVR] Error running job 1683597600-614 Shepherds Chapel @ 7PM: could not start stream on channels=[3777]: M3U: Stream Not Available
I'm pretty sure hlstube is what caused the failure,
but Channels DVR should have shown the failure in the Scheduled jobs.
Submitted diagnostic logs bcbed194-c97f-454c-ac46-0f26991cb973
Will also submit them if/when it happens again.
This was fixed in newer prerelease
I was running the latest when it happened
2023/05/06 18:04:20.137694 [SYS] Starting Channels DVR v2023.05.07.0017 (linux-x86_64 pid:8) in /channels-dvr/data
Ah fix wasn't pushed yet. Next build
