Recording fail
I recorded Alabama vs Ole Miss on Saturday and ended it before time schedule. It seemed to work on plex but on 2 harddrives the file fails to play. Do I need to modify the file to work properly or split it? What do you guys suggest.
You need to check the dvr logs to see what exactly happened
is there a way to patch the file to work properly? ffmpeg?
can't recommend a fix until you actually diagnose the issue first
