Recording indicates wrong length 41 hours 50 minutes
This morning's recording of the Today show would not play back correctly - it was kind of jittery with no audio - I looked at the Channels DVR web page and the recording indicates it is 41 hours 50 minutes in length (so I am trying reindexing and rebuilding timestamps) - anyone else ever had this problem?
Where was it recorded from?
If you update to prerelease before fixing timestamps it should work.
Recorded from an HDHomerun Quatro - I transferred the file and tried to fix with VideoRedo quick stream fix and it didn't work - it said there was a "ring buffer overflow" - the file size is consistent with recordings from the previous couple of days - I'll try to update to pre-release and fix timestamps
Update: I think the file may be corrupt - for some reason I can't copy it back to the DVR PC via windows - may just have to delete this one
Could be there was really bad signal issues.
Check the dvr log for the [SNR] line after the recording finished
I got the file copied back and am regenerating video index - seems to be running a long time
