When we record shows, the playback of the show is missing segments of the show. Example: show records for 15 minutes, interruption for 25 minutes so that part of the show is missing, last part of the show is recorded.
How to fix?
How to fix?
I'm having the same problem!
Submit diagnostics from the server after it happens.,
What source is the recordings from TVE or OTA?
the logs would tell you if there was signal issues with OTA, or network issues with a TVE stream.
How to access diagnostics? Several shows are unwatchable because so much of the recording is missing. It is from streaming channels, not over the air. Very frustrating.
Please go to Settings -> Support -> Submit Diagnostic Logs from your device and let us know when it's been submitted so we can have a better idea of what was going on.
I do not have access to the server. I am watching away from home where the server is located. Is there a way to access the diagnostic logs remotely?
You can submit the diagnostics from the device and we can view them.
If you want to access your own DVR logs, you can do it by going to https://my.channelsdvr.net/
I accessed the diagnostics and I got this message on top. McAffee is no longer an active subscription, but could it still interfere with recordings. Found third-party firewall software: McAfee Firewall.
We recommend using the built-in Windows Defender Firewall for best results and security.To continue using third-party software, please check the manual for your firewall for instructions on how to add whitelists for:
Here is more info on the page:
Version
2022.03.23.0209
Check For Update
Uptime
a month
Started 05/11/2022
Timezone
EDT
OS
Dell Inc. Inspiron 7773
Windows Microsoft Windows 10 Home
10.0.19043 Build 19043 (kernel: 10.0.19043 Build 19043)
CPU
8 cores / Intel(R) Core(TM) i7-8550U CPU @ 1.80GHz
load averages: 0.56 0.78 2.30
RAM
15.84 GB
47.0% free
NET
1 interface
192.168.0.165
Disk
25.2% used
1.35 TB available
Activity
Recording ch9076 for Gaslit until 9:02PM.
Watching Life Below Zero - Season 18, Episode 4 from Jane's 5th Fire TV
Watching ch9084 from 174.211.178.194 (Remux Finished)
Watching ch9087 from 174.211.178.194 (Remux Finished)
Watching ch9088 from 174.211.178.194 (Remux Finished)
Watching The Last Waltz (1978) from 184.60.5.79 (Transcoder Ready).
Bonjour
Advertising dvr-desktop-q4fdlnb.local. via 0 networks: [192.168.0.165]
DVR
4 sources found
Add Source
PBS
test
MOVIES
Spectrum
Stats
12 Passes
33 Shows
100 Recordings
Maintenance
Last backup 15 hours ago
Storage Paths
C:\DVR
Status
Idle
Stats
2 Lineups
14,881 Shows
60,584 Listings
281.48 MB on disk
Maintenance
Last refreshed an hour ago
Padding
Keep
All
Unwatched Only
Last 3 Only
Remove Items From Trash After
10 days
Status
Idle
Enabled
Detect Commercials
Thread Count
1234567
Status
Idle
Movie Sources
TV Sources
Video Sources
Maintenance
Transcoder
Software
Deinterlacer
BlendLinear
Adaptive Streaming
OnOff
Automatically adjust bitrate based on available bandwidth
Cache
19.76 GB on disk
Server Quality
1080p @ 10mbps
Client Buffer
30 seconds
Enable
OffOn
Port Forwarding
ManualAutomatic
Configure your router to forward TCP port 8089 to 192.168.0.165
URL
MCEBuddy Metadata
Export .json file next to each recording for MCEBuddy processing
EDL Export
Export .edl file next to each recording for auto-skip in external video players
VideoReDo Export
Export .vprj file next to each recording for editing in VideoReDo
VLC links
Show VLC links in the web UI. Requires installation of vlc-protocol helpers.
Local Networks via TV Everywhere
Some major metropolitan area offer access to NBC, ABC, CBS and FOX stations via TV Everywhere
Old Transcoder
Use deprecated transcoder for recorded content. Intended to be used for testing if there are problems with remote streaming.
Web Player Adaptive Streaming
Use adaptive streaming for the web player in the browser. This is known to have issues on some browsers.
HTTP Logging
Record all HTTP requests to the DVR log
