On AppleTV if I exit playback of recording then maybe watch some live TV come back to resume playback it just stops before it plays anything. However, if I then go to another recording then that one plays OK then coming back to the previous failed playback it now plays successfully.
Please submit diagnostics after this happens and reply once they have uploaded.
Diagnostics uploaded having reproduced the problem so if you have a fix I can easily do same test
Just did same test on iPad and same fault occurs
Update 3.2.27 on AppleTV installed 26/9/2019 and may have resolved the problem. Update on iPad suggests same but wonder if it’s the reinstall rather than an actual fix that may have resolved it.
I will monitor things for a while and if same issue arises I will raise new issue and send diagnostics.
