Recording rules between ATV and web
When I go to the web up, there is a rule for unwatched only and unwatched + (several varieties)
These don’t exist on the ATV.
I want most of the show to delete after watching. ( if not immediately, the. Soon)
The rule I set on the web didn’t den to work, and I think that l looked at them from the appleTV afterward.
Now if I set to I watched only the. Save the rule and exit, when I immediately reenter, it’s set to unwatched +3.
If I change the setting in the Apple TV, then look at it on the web, it has ALL and Last3 set.
I am running the latest beta and accessing the web from my iPhone.
Will try to reproduce…
Screenshots would help too.
Here you go again trying to get me to use a computer :wink:
I have emailed . I can’t paste pictures on the iPhone into this entry.
Ok, as far as the web ui is concerned, I did see that it looked right on the pc. If I set it correctly on the phone it shows right on the PC web.
The one bug with the web on my iPhone is that if I have either “All” or “Unwatched only” selected ONLY, After saving, when I go back to look at it on the phone, it has that setting selected (grey) AND “last 3 only” selected. It’s apparently a visual only problem, as that is actually not set, since it makes invalid combinations ( ex. All and last 3 only)
Now as far as the Apple TV options are concerned,
There is still no “Unwatched Only” option available.
