I'm trying to set up primary and fallback recordings for new episodes of series. I've tried setting up two series passes, one for the earlier showing via TVE and a second one for the later showing via HDHR at a different location. That leads Channels to only see the earlier pass as the sole pass.
I've tried a single pass with two different Channel CONTAINS values but that leads to an "Error: Job Not Found" for one of the two airings. Usually the latter airing.
The reason for the setup is in case the TVE feed is not working, or if it drops portions of the show and becomes incomplete, or if the network connection is down then there is the backup HDHR feed that shouldn't have any issues with feeds.
Diagnostics 311493e3-71a1-44d2-b133-7797989070b5
