Recording Stopping after 44 min
I am using the DVR from GetChannels but for my last 3 recording the DVR stopped recording 44 minutes into the program and then when I go to the channel it says “Invalid Tuner” but if I quite getchannels and restarted it I can then access the channel.
Please check the Log tab on the DVR and post the log entries from around the time the recording was taking place.
The ATV can show a message like “Tuner not available”… is that what you mean? There is no message “Invalid Tuner” as far as I know.
What HDHomeRun model are you using?
Sorry, yes it says “Tuner Not Available”
HDHomeRun Extend
Can you check the hdhomerun web interface for the system log and see if it shows any errors?
Sounds like this might be the same problem as HDHomeRun EXTEND "reset reason = application watchdog"
S13E16 Who Is He And What Is He to You.mpg: file too large
2017/03/16 20:03:59 [DVR] Job 1489712340-2 ended prematurely: 618.466751ms
2017/03/16 20:03:59 [DVR] Starting job 1489712340-2 Grey’s Anatomy on ch=[7.1]
2017/03/16 20:03:59 [DVR] Recording for job 1489712340-2 from 1054B7C3 ch7.1 into “TV/Grey’s Anatomy/2017-03-16-1859 Grey’s Anatomy 2017-03-16 S13E16 Who Is He And What Is He to You.mpg” for 616.734027ms
2017/03/16 20:03:59 [ERR] Failed writing to file during job 1489712340-2: write /Volumes/IOMEGA HDD/DVR/TV/Grey’s Anatomy/2017-03-16-1859 Grey’s Anatomy 2017-03-16 S13E16 Who Is He And What Is He to You.mpg: file too large
2017/03/16 20:03:59 [DVR] Job 1489712340-2 ended prematurely: 395.065246ms
2017/03/16 20:03:59 [DVR] Recording for job 1489712340-2 from 1054B7C3 ch7.1 into “TV/Grey’s Anatomy/2017-03-16-1859 Grey’s Anatomy 2017-03-16 S13E16 Who Is He And What Is He to You.mpg” for 393.380278ms
2017/03/16 20:03:59 [DVR] Job 1489712340-2 ended prematurely: 192.761611ms
2017/03/16 20:04:00 [DVR] Recording for job 1489712340-2 from 1054B7C3 ch7.1 into “TV/Grey’s Anatomy/2017-03-16-1859 Grey’s Anatomy 2017-03-16 S13E16 Who Is He And What Is He to You.mpg” for 191.03588ms
2017/03/16 20:04:00 [ERR] Failed writing to file during job 1489712340-2: write /Volumes/IOMEGA HDD/DVR/TV/Grey’s Anatomy/2017-03-16-1859 Grey’s Anatomy 2017-03-16 S13E16 Who Is He And What Is He to You.mpg: file too large
I have plenty of space on my external disk:
Capacity: 999.96
Available: 936.99
Another error:
2017/03/14 20:57:55 [DVR] Job 1489543140-4 ended prematurely: 4m4.283784533s
2017/03/14 20:57:55 [DVR] Starting job 1489543140-4 This Is Us on ch=[9.4 9.1]
2017/03/14 20:57:56 [DVR] Recording for job 1489543140-4 from 1054B7C3 ch9.4 into “TV/This Is Us/2017-03-14-1959 This Is Us 2017-03-14 S01E18 Moonshadow.mpg” for 4m4.281303324s
2017/03/14 20:57:56 [ERR] Failed writing to file during job 1489543140-4: write /Volumes/IOMEGA HDD/DVR/TV/This Is Us/2017-03-14-1959 This Is Us 2017-03-14 S01E18 Moonshadow.mpg: file too large
Thanks for the logs. The error you’re seeing is “file too large” and is coming from your operating system.
Can you copy/paste the OS/CPU section from the top of the DVR settings page so I can know what kind of computer/NAS you’re running the DVR on?
You might want to look into the filesystem or filesystem configuration of where your DVR is storing your recordings. Some older filesystems don’t support files over 4GB or have support for large files turned off by default. HD MPEG2 will run 6-8GB for an hour show so 44 min mark would be when you are exceeding 4GB.
I would guess you’re running on windows and your drive is formatted FAT32
