I have a pass for Fixer Upper, and noticed a number of the files are marked as "interrupted" and are corrupted, some mentioning long lengths like 1531min. The logs look very confusing:
2019/11/19 11:59:50 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 11:59:50 [DVR] Waiting 59m59.988914749s until next job 1574186390-12 Fixer Upper
2019/11/19 12:00:13 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:00:13 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 1h0m19.988743919s
2019/11/19 12:00:13 [IDX] Generating video index for job 1574182790-12
2019/11/19 12:08:27 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=548c058a0697450b8d1edd09aa3c3279&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=2: 403 Forbidden
2019/11/19 12:08:27 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=2 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=476.531689
2019/11/19 12:08:27 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:08:27 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 51m42.280680178s
2019/11/19 12:08:27 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:08:27 [DVR] Waiting 51m22.264132888s until next job 1574186390-12 Fixer Upper
2019/11/19 12:08:29 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:08:29 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 51m42.264006983s
2019/11/19 12:19:40 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=f5bef26e06ee4041b06e8bd2c295a807&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=7: 403 Forbidden
2019/11/19 12:19:40 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=6 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=1166.863633
2019/11/19 12:19:40 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:19:40 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 40m29.318725772s
2019/11/19 12:19:40 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:19:40 [DVR] Waiting 40m9.298967084s until next job 1574186390-12 Fixer Upper
2019/11/19 12:19:43 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:19:43 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 40m29.298845735s
2019/11/19 12:30:51 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=168bda34acbe420aabf202d8b2051e8d&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=6: 403 Forbidden
2019/11/19 12:30:51 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=5 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=1837.915356
2019/11/19 12:30:51 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:30:51 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 29m18.239369757s
2019/11/19 12:30:51 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:30:51 [DVR] Waiting 28m58.222603639s until next job 1574186390-12 Fixer Upper
2019/11/19 12:30:54 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:30:54 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 29m18.222476401s
2019/11/19 12:31:39 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=3dafcb96d65347058e5e14d04176988d&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=1: 403 Forbidden
2019/11/19 12:31:39 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=1 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=1885.750433
2019/11/19 12:31:39 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:31:39 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 28m30.375215889s
2019/11/19 12:31:39 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:31:39 [DVR] Waiting 28m10.358556029s until next job 1574186390-12 Fixer Upper
2019/11/19 12:31:39 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:31:39 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 28m30.358433697s
2019/11/19 12:39:37 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=3dafcb96d65347058e5e14d04176988d&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=4: 403 Forbidden
2019/11/19 12:39:37 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=2 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=2363.054489
2019/11/19 12:39:37 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:39:37 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 20m32.851907449s
2019/11/19 12:39:37 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:39:37 [DVR] Waiting 20m12.832684615s until next job 1574186390-12 Fixer Upper
2019/11/19 12:39:39 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:39:39 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 20m32.832559135s
2019/11/19 12:40:14 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=f7cf9be7a0544f0fb09e7ef0b2332946&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=0: 403 Forbidden
2019/11/19 12:40:14 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=2393.341767
2019/11/19 12:40:14 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:40:14 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 19m55.987141581s
2019/11/19 12:40:14 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:40:14 [DVR] Waiting 19m35.969610665s until next job 1574186390-12 Fixer Upper
2019/11/19 12:40:14 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:40:14 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 19m55.969456131s
2019/11/19 12:41:06 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=f7cf9be7a0544f0fb09e7ef0b2332946&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=2: 403 Forbidden
2019/11/19 12:41:06 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=1 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=2448.003444
2019/11/19 12:41:06 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:41:06 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 19m3.670584655s
2019/11/19 12:41:06 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:41:06 [DVR] Waiting 18m43.652901764s until next job 1574186390-12 Fixer Upper
2019/11/19 12:41:07 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:41:07 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 19m3.65277934s
2019/11/19 12:46:48 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=fed0509dc6a5449582f74661af2a3c3b&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=3: 403 Forbidden
2019/11/19 12:46:48 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=2 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=2796.265411
2019/11/19 12:46:48 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:46:48 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 13m21.100828185s
2019/11/19 12:46:48 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:46:48 [DVR] Waiting 13m1.083684741s until next job 1574186390-12 Fixer Upper
2019/11/19 12:46:50 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:46:50 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 13m21.08356041s
2019/11/19 12:47:35 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=923c82b4e4ce4b758ce2d8efab5320fd&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=1: 403 Forbidden
2019/11/19 12:47:35 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=1 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=2842.889344
2019/11/19 12:47:35 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:47:35 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 12m34.465906044s
2019/11/19 12:47:35 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:47:35 [DVR] Waiting 12m14.448266665s until next job 1574186390-12 Fixer Upper
2019/11/19 12:47:35 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:47:35 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 12m34.44813863s
2019/11/19 12:48:32 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=923c82b4e4ce4b758ce2d8efab5320fd&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=3: 403 Forbidden
2019/11/19 12:48:32 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=1 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=2899.764767
2019/11/19 12:48:32 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:48:32 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 11m37.012053281s
2019/11/19 12:48:33 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:48:33 [DVR] Waiting 11m16.995779695s until next job 1574186390-12 Fixer Upper
2019/11/19 12:48:34 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:48:34 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 11m36.995650493s
2019/11/19 12:53:06 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=7a55baabadd24b258ec4e09fb651083d&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=2: 403 Forbidden
2019/11/19 12:53:06 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=2 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=3178.358600
2019/11/19 12:53:06 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:53:06 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 7m3.52751264s
2019/11/19 12:53:06 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:53:06 [DVR] Waiting 6m43.511041913s until next job 1574186390-12 Fixer Upper
2019/11/19 12:53:08 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:53:08 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 7m3.510921341s
2019/11/19 12:54:07 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=d55654c7fb224d38b2447f754abc45f7&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=1: 403 Forbidden
2019/11/19 12:54:07 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=1 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=3232.749967
2019/11/19 12:54:07 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:54:07 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 6m2.215889415s
2019/11/19 12:54:07 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:54:07 [DVR] Waiting 5m42.199059362s until next job 1574186390-12 Fixer Upper
2019/11/19 12:54:09 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:54:09 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 6m2.198937494s
2019/11/19 12:54:57 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=a402373c24e746e8b839ddda05608815&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=1: 403 Forbidden
2019/11/19 12:54:57 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=1 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=3281.773967
2019/11/19 12:54:57 [TNR] Closed connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:54:57 [DVR] Job 1574182790-12 Fixer Upper ended prematurely: 5m12.383281686s
2019/11/19 12:54:57 [DVR] Starting job 1574182790-12 Fixer Upper on ch=[6104]
2019/11/19 12:54:57 [DVR] Waiting 4m52.363695516s until next job 1574186390-12 Fixer Upper
2019/11/19 12:54:57 [TNR] Opened connection to TVE-buc020 for ch6104 HGTV
2019/11/19 12:54:57 [DVR] Recording for job 1574182790-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg" for 5m12.363531241s
2019/11/19 12:59:50 [DVR] Starting job 1574186390-12 Fixer Upper on ch=[6104]
2019/11/19 12:59:50 [DVR] Waiting 59m59.989255924s until next job 1574189990-12 Fixer Upper
2019/11/19 12:59:50 [TNR] Sharing existing connection to TVE-buc020 for ch6104 HGTV (clients=2, len=0)
2019/11/19 12:59:50 [DVR] Recording for job 1574186390-12 from TVE-buc020 ch6104 into "TV/Fixer Upper/Fixer Upper S03E03 2015-12-15 A Family Searches a Small Town for the Ultimate Open Space 2019-11-19-1259.mpg" for 1h0m19.989128s
2019/11/19 12:59:50 [IDX] Generating video index for job 1574186390-12
2019/11/19 13:00:10 [MTS] Statistics for "TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg": skipped=0 unhandled_packets=0 discontinuity_detected=0 transport_errors=0 invalid_pts=0 invalid_dts=0 saw_pcr=false saw_pmt=true highest_pts=3627.133789
2019/11/19 13:00:10 [DVR] Finished job 1574182790-12 Fixer Upper
2019/11/19 13:00:10 [DVR] Waiting 59m39.689308102s until next job 1574189990-12 Fixer Upper
2019/11/19 13:00:10 [DVR] Processing file-129: TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg
2019/11/19 13:00:12 [DVR] Running commercial detection on file 129 (TV/Fixer Upper/Fixer Upper S02E05 2015-01-27 Almost Empty Nesters Want Waterfront Home 2019-11-19-1200.mpg)
2019/11/19 13:11:37 [ERR] Error during stream TVE-buc020 ch6104 HGTV: Failed to download file: https://x-default-stgec.uplynk.com/ausw/slices/5a5/4f59ea65df184a2580ad8fc80d3eaa32/5a5940f011014ef1ad91de72ea340a5c/H0000000A.ts?pbs=a402373c24e746e8b839ddda05608815&_jt=l&chid=e047db886d7b42499309a9d3f9e12a7e&oid=e6cf0c55dac249f0a0f72e7c72e6f6cb&si=5: 403 Forbidden
